jpdriver1 Posted September 22, 2006 Share Posted September 22, 2006 I've just recently replaced the motor in the 90, the vacuum lines are hooked up to match the diagram, but it will not run with the map sensor connected to the vacuum line. tonight I replaced the sensor no change, any ideas? :bowdown: Link to comment Share on other sites More sharing options...
Pete M Posted September 22, 2006 Share Posted September 22, 2006 Does it try to start but can't? Do you have spark? Do you have fuel? Link to comment Share on other sites More sharing options...
jpdriver1 Posted September 29, 2006 Author Share Posted September 29, 2006 yep plenty of both --- small amount of black smoke with MAP unhooked, hook up map --- dies Link to comment Share on other sites More sharing options...
RedBullMJ Posted January 11, 2007 Share Posted January 11, 2007 yep plenty of both --- small amount of black smoke with MAP unhooked, hook up map --- dies Did you have a solution to this?? Link to comment Share on other sites More sharing options...
