transfercase stuck in gear
Auto, or stick?
If you went so far as pulling the ft driveshaft (and it still won't come out of gear),
it's probably jammed more than what I've dealt with,
but bumping it a few times, going from fwd to reverse is usually enough to free up the 'typical' stuck T-case.
Either way, I wouldn't put too much force on the linkage (with a wrench),
'some' force may be OK, but too much and you'll be looking at having to tear it down to fix it (if your not already).
