blusteve Posted December 19, 2009 Share Posted December 19, 2009 Doing the 97+ fronend conversion, sheetmetal is going on fairly easy, but am wondering the best way to wire the headlights, turn signals and side markers. Can I use the old harness and splice the extra wires needed? Any help will be appreciated. Link to comment Share on other sites More sharing options...
johnnyc Posted December 19, 2009 Share Posted December 19, 2009 Doing the 97+ fronend conversion, sheetmetal is going on fairly easy, but am wondering the best way to wire the headlights, turn signals and side markers. Can I use the old harness and splice the extra wires needed? Any help will be appreciated. The wiring is the easiest part. Hopefully, you have the bulb sockets for the new header panel. Just splice the newer sockets into the old harness. I used butt connectors and heat shrink. The newer turn signals do have two bulbs instead of the original one. I'm just using the outermost bulb on each side. The other holes are capped off with the unused sockets to prevent moisture from entering. One of these days, I'll splice the other sockets into place and get them opearational. But for now, it works just fine. Link to comment Share on other sites More sharing options...
mfpdm Posted December 20, 2009 Share Posted December 20, 2009 I took the opposite sides of each harness and made a jumper harness which allows you to unplug the original harness if needed. I never like splicing into my original harness if I don't have to. You can see it here. viewtopic.php?f=9&t=11270 :cheers: Link to comment Share on other sites More sharing options...
blusteve Posted December 20, 2009 Author Share Posted December 20, 2009 I like the idea of using a jumper to connect the old to new, however when I bought my doghouse I did not get the harness end that attachest to the jeep side. Does anyone have an extra end tht would work for me and if so how much shipped to 47119 Link to comment Share on other sites More sharing options...
87Warrior Posted December 20, 2009 Share Posted December 20, 2009 I may have an extra harness with several inches of the Jeep side of the plug. It came out of a 98. I will double check on it tomorrow when I get back home. Link to comment Share on other sites More sharing options...
blusteve Posted December 21, 2009 Author Share Posted December 21, 2009 are the color coded wires the same functions on a early or late model comanche and cherokee Link to comment Share on other sites More sharing options...
james750 Posted December 21, 2009 Share Posted December 21, 2009 The easiest way I see to handle the wiring is to get a new front end wiring harness, and the connector that it connects to. Then, take apart the old connector and plug all the wires into the new connector. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted December 21, 2009 Share Posted December 21, 2009 You know you can just swap your existing (pre 97) headlight buckets from side to side and they bolt up and fit with the newer style headlight bezels. You than don't have to splice anything as far as headlights go. All you'll need to do is worry about the turns. Link to comment Share on other sites More sharing options...
mfpdm Posted December 21, 2009 Share Posted December 21, 2009 The easiest way I see to handle the wiring is to get a new front end wiring harness, and the connector that it connects to. Then, take apart the old connector and plug all the wires into the new connector. Would be nice but the connectors are different so the pins from the older will not go into the newer. Also if you ever decide to go back to the original, your doing the wiring again. are the color coded wires the same functions on a early or late model comanche and cherokee Fraid not. That would be too simple. The Thing about the 97+ is that they used a wire for each sides functions verse the earlier combined what wires they could, ie grounds. here's a bigger pic from my thread above that may help you out. You'll notice that some wires from the old connector have two wires from the new connector attached to it. I basically set them side by side and figured what did what. If the son comes home soon, I'll go get the wiring pin out for you and post it. Then all you have to do is figure out if you just want to splice them or get the connectors as I did. :cheers: Link to comment Share on other sites More sharing options...
mfpdm Posted December 22, 2009 Share Posted December 22, 2009 Here's the pin out from my 86 with the 97+ header. Colors may vary a little between years and due to my eye sight. :D But this should get you done. :cheers: Link to comment Share on other sites More sharing options...
blusteve Posted December 22, 2009 Author Share Posted December 22, 2009 thanks everyone will let you know how things turn out Link to comment Share on other sites More sharing options...
