Didn't see it in the FAQ...
Subject: 1991 2WD with AX-15
Can trans be "reused" in swap? (i.e. is the output shaft the same)
I'm guessing the output housing will change but are the guts the same?
Thanks
yes it's possible to convert, but it will likely be much more money than finding a 4wd trans and selling off your 2wd AX-15. :thumbsup:
