Stock bumper bolt size
I found one of the broken off pieces of bolt from a year ago when I installed this bumper. They are 10mm with a 1.5 thread pitch. I got 10.9 grade bolts as well as grade 8 SAE bolts to replace the craptastic 8.8 grade metric hardware I have been using for the last year.
The reason for this whole bolt issue was that about a year ago the front of my truck was hit, all 6 front bumper bolts sheared off (thank god that those gave rather than the frame), I lost all 4 of the front factory welded nuts, but fortunately the nuts in the frame rail didn't break free, after a year of running a JCR prerunner bumper with only the front 2 mounting bolts held on with 8.8 hardware as well as the tie in brackets (I know, bad idea), I finally got everything upgraded. Now I won't cringe every time that I am recovering a Jeep wondering if the bumper will hang on. :D
