cluricaunne Posted December 2, 2009 Share Posted December 2, 2009 Okay, so I think I am about to replace the fuel pump in my MJ, for the 3rd time this year. Which of course would mean that it is time to drop the tank and clean it, perhaps even line it... So: any suggestions for tank cleaners and or liners?? Link to comment Share on other sites More sharing options...
mvusse Posted December 2, 2009 Share Posted December 2, 2009 I had the same problem. After 3 pumps in relatively short order I just wiped the tank clean with a towel and picked up any itty bitty pieces of gravel left in it. Then put a new sock on the last bad pump, and it turns out the pump is fine. Still fine almost a year after I barely managed to limp into my parents' drive way going 20mph bucking and backfiring. A plugged up sock makes the pump run loud and flow less fuel. No way to diagnose between a plugged sock and a bad pump without replacing the sock to try it. Link to comment Share on other sites More sharing options...
ratrapp Posted December 3, 2009 Share Posted December 3, 2009 i hate to say it but you should bite the bullet and replace the tank.i had to about 6 years ago.i didn't realize how much crap was inside my tank.i also went through 3 pumps ina year and a half before replacing the tank.the first 2 were mopar pumps as well. Link to comment Share on other sites More sharing options...
Disturbed Posted December 3, 2009 Share Posted December 3, 2009 I just bought a new tank, about $150 to my door. If you are going through pumps that fast the $150 investment seems like the smart move. The tank came bare steel so I am wondering if I should paint the outside of the tank before I install it? Any input? Link to comment Share on other sites More sharing options...
mvusse Posted December 3, 2009 Share Posted December 3, 2009 Tank is probably galvanized steel. You can paint it if you like, but it won't make much of a difference if you don't. Link to comment Share on other sites More sharing options...
Wildman Posted December 4, 2009 Share Posted December 4, 2009 I'd say........Paint the new tank, but use this product - http://www.rustoleum.com/product.asp?fr ... d=55&SBL=1 It's resistant to gas :brows: Or, go full out with this product - http://www.por15.com/SPECIAL-Sealer-Met ... tinfo/S7Q/ Link to comment Share on other sites More sharing options...
cluricaunne Posted December 6, 2009 Author Share Posted December 6, 2009 there are three relays just behind my battery, which one of them is the fuel pump relay?? Link to comment Share on other sites More sharing options...
Wildman Posted December 7, 2009 Share Posted December 7, 2009 If you have only 3 relays, it would be the middle one for the fuel pump. Link to comment Share on other sites More sharing options...
jpnjim Posted December 7, 2009 Share Posted December 7, 2009 I went for a new Ebay tank when I got this MJ. Link to comment Share on other sites More sharing options...
Shandley Posted December 7, 2009 Share Posted December 7, 2009 Hey jpnjim, Why didn't you buy the one with big tires? :brows: :D :rotf: $150 for a fuel tank??? Jeez man, I'm moving to the states whenever I have vehicle trouble. Link to comment Share on other sites More sharing options...
ajpolitz Posted December 7, 2009 Share Posted December 7, 2009 http://www.rockauto.com rules for this stuff. SPECTRA PREMIUM Part # JP5B 113" Wheel Base; (6' Box); Lock Ring Kit Included A $123.79 $0.00 $123.79 Fuel/Air : Fuel Filter FRAM Part # G3641 {In-Line Gasoline Filter} B $9.15 $0.00 $9.15 Fuel/Air : Fuel Pump CARTER Part # P74155 {In Tank Fuel Pump and Strainer Set} w/Bosch OE Pump B $89.79 $0.00 $89.79 And only $22.00 to ship. Anthony Link to comment Share on other sites More sharing options...
cluricaunne Posted December 8, 2009 Author Share Posted December 8, 2009 I get better prices at my local parts stores, being a vendor and all. I can get the pump for 69 and the filter for 6.50. The fuel tank I can get used for $30 or just get one off ebay for 100 or so. Rock Auto is a great place if you can't get vendor pricing though. Link to comment Share on other sites More sharing options...
cluricaunne Posted December 14, 2009 Author Share Posted December 14, 2009 Spent all weekend working on it, finally figured out the problem. Water in the tank. Had to drop the tank, drain it, clean it, and clean out the lines. Everything is working fine now, so I can drive it through the winter, and then get back to restoring it. Link to comment Share on other sites More sharing options...
Shandley Posted December 14, 2009 Share Posted December 14, 2009 That's great! Congrats on keeping the rare. Say, how does water get into the tank? Link to comment Share on other sites More sharing options...
cluricaunne Posted December 14, 2009 Author Share Posted December 14, 2009 different ways, condensation, weather changes, even when you fill up at the gas pumps. Normally its in small amounts, and just burns off with the fuel, and I do recommend using: it helps a lot. Unfortunately, I wasn't using it, and collected a bit more water than the fuel system could process... Link to comment Share on other sites More sharing options...
