ok. so I'm ordering some 4.56 gears and what not for the truck, now I'm just wondering what else i need to do in order to install the gears? should i buy an axle overhaul? just certain bearings? there is alot of info out there its just not so clear it seems :???: i will be doing the same thing with my d30 front. also will the stock spring plates(things with shockmounts) work after the soa?( I'm not using the stock spring mount if it does work) i think thats all for now :dunno: thanks for all the help! and hopefully she will be on the road soon!
If you don't know what all you need to do it, you'd be better off paying a professional drive train shop to do it. Everything about the gears needs to be set to certain specs with very tight tolerances.
i have someone experienced who will be there with me to show me and oversee etc... i just want to make sure i have all the necessary parts when we go to put it all together
its best to get a master install kit for each axle when you install new gears. that way you have new bearings and shims etc. the stock mj spring plates won't work since the 8.8 has larger tubes than any axle the came stock in a mj. i used the stock explorer plates when i put an 8.8 in mine. you'll need to come up with some sore of shock mounts too.
