lostissues Posted March 30, 2010 Author Share Posted March 30, 2010 no ballast resistor on my truck Link to comment Share on other sites More sharing options...
dasbrick Posted April 2, 2010 Share Posted April 2, 2010 Hey if you're still having this issue, replace the fuel pump. I went through this EXACT problem. It was the pump. Link to comment Share on other sites More sharing options...
Lloyd Posted April 2, 2010 Share Posted April 2, 2010 The pump sock is a problem I had also. But I had bought a new pump before I realized it, so now I have a spare good pump that just needs a sock if I ever need it. I also had a problem with the catalytic converter. Took it off and hollowed it out by driving a 3/4 inch x 4 foot piece of pipe through it a few times. Link to comment Share on other sites More sharing options...
one_bad_MJ Posted April 2, 2010 Share Posted April 2, 2010 POP and Bang could be from dizzy being out of time OR plug wires on wrong OR bad compression in 2 or more cyls compression test it. check your firing order and check your Dizzy Check your engine grounds too. add one you never know... Link to comment Share on other sites More sharing options...
lostissues Posted April 3, 2010 Author Share Posted April 3, 2010 just checked some vacuum things, the fuel pressure regulator has 16-17 in.Hg vac the input of the EGR solenoid had the same, the output has nothing and when I unplugged the electrical connector I still had nothing. does that mead bad EGR solenoid? Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 5, 2010 Share Posted April 5, 2010 just checked some vacuum things, the fuel pressure regulator has 16-17 in.Hg vac the input of the EGR solenoid had the same, the output has nothing and when I unplugged the electrical connector I still had nothing. does that mead bad EGR solenoid? According to the diagnostic procedure (first page last two bullet points), vacuum should be present when you unplug the connector, so it seems like a bad solenoid. Link to comment Share on other sites More sharing options...
lostissues Posted April 8, 2010 Author Share Posted April 8, 2010 ok well i was able to go the another junk yard and find some parts, I grabbed a fuel pressure regulator and a ERG solenoid. tried swapping them in and it did nothing. so today I pulled out my sending unit and the JB weld we put on the tubes did not hold very well, when I pulled it out I'm guessing the sock was not attached, it is simple to snap on and would seam like it could fall off easily. with the tubes being free to move the pump probably is able to slam into the bottom of the tank and knock the sock off. could the pump not being positioned correctly be the problem or the sock not being attached make it run like crap? well either I need to figure out a new way to sent fuel or get a new (new/used most likely because no one make them anymore) one or have this one repaired. luckily I have the 32 gal tank with a special sending unit so it should make it super easy to find one right :roll: Link to comment Share on other sites More sharing options...
