Lower Control Arms-is this a good replacement?
If I was going to replace my lower control arms, theres no way I would go back with stock replacement units unless they were free. I agree with the WJ replacements. The WJ upper arms are also the correct length to replace your upper arms and are built much better. I have a whole set that I will install when I finish my 4x4 conversion. Let us know what you end up doing!
You could try searching car-part.com for other WJ-only items and calling those yards about the arms.
The WJ metal sleeves will need to be trimmed a bit to MJ specs.
And this probably isn't required, but while I was in there I trimmed the arms and the axle a bit for maximum articulation. :D
