jeepcoma Posted September 21, 2009 Posted September 21, 2009 Someone local is parting out a '95 V8 ZJ. He says I can take the coil springs for $25, front suspensions pieces for $25 (for everything, but mainly I want the swaybar and will grab anything that swaps), and the steering box for $50. So for $100 I can pretty much take all I need. I have to go yank them myself, but do these seem like fair prices or would I save a bunch of bucks at the junkyard? I've read the steering boxes are getting hard to come by, but I'm not sure I want it $50 bad.
jpdocdave Posted September 21, 2009 Posted September 21, 2009 i think its good, steering boxes seem to be going for closer to 100 for some reason.
BJA814 Posted September 21, 2009 Posted September 21, 2009 Grab the tie rod while your at it. It's a solid one.
comanche09 Posted September 21, 2009 Posted September 21, 2009 Sounds pretty fair. I try to compare prices to what my local u-pull would charge... ($125 for a complete 4x4 front axle) and of course only buy from someone who is selling for less. I am goin to acquire a Dana 30 complete from a guy off of craigslist for $50 including springs, rotors etc, only it has one bent knuckle... I got my MJ from CL
HOrnbrod Posted September 21, 2009 Posted September 21, 2009 That's a pretty good price for the steering box. How many miles on it? The guys w. older GM hotrods are snapping up the quick ratio 93-98 ZJ boxes up pretty quickly as they are a bolt-in for their cars using a new rag wheel.
Tri_X_Troll Posted September 22, 2009 Posted September 22, 2009 While we're on steering boxes........I remember that the TJ guys were big on swapping the dodge durango steering boxes into their wranglers and some of the XJ guys were swapping them into the XJ's with little modification. Will one drop into a 1986 Comanche?
HOrnbrod Posted September 22, 2009 Posted September 22, 2009 While we're on steering boxes........I remember that the TJ guys were big on swapping the dodge durango steering boxes into their wranglers and some of the XJ guys were swapping them into the XJ's with little modification. Will one drop into a 1986 Comanche? The piston bore is a larger diameter on the Durango boxes, so it needs to be shimmed out about 1/4" shims or so between the frame and steering box body for clearance. Plus the stock steering ratio of the Durango boxes is a higher ratio than the stock MJ/XJ box ratio. Rugged steering box though.
