seebold Posted September 12, 2009 Share Posted September 12, 2009 Well pi'c tell a 1000 words My fron't end has a slight wobble if i hit a bumb just right trying to correct the problem myself but still haveing problems. :dunno: I need a fron't end GURU :wall: Link to comment Share on other sites More sharing options...
Pete M Posted September 12, 2009 Share Posted September 12, 2009 what's your caster set to? Link to comment Share on other sites More sharing options...
Geonovast Posted September 12, 2009 Share Posted September 12, 2009 Looks like the right spring is bent inward on the bottom, but the left spring is perfectly straight. Is your tracbar adjustable? Link to comment Share on other sites More sharing options...
aemsee Posted September 12, 2009 Share Posted September 12, 2009 Hitting those bumb's will do that :D . From what can be seen in the pic, looks like you might be running very little positive caster. Also check your control arm bushings. Link to comment Share on other sites More sharing options...
seebold Posted September 13, 2009 Author Share Posted September 13, 2009 Well as far as a bent spring. thats just camara play there good, but what is caster? and the track bar is adjustable. yea the bushing might be alittle sloppy thats like a whole outher can a worms... i don't know what kind of lift it has and i don't thing stock bushing will work? Link to comment Share on other sites More sharing options...
Eagle Posted September 13, 2009 Share Posted September 13, 2009 seebold said: Well as far as a bent spring. thats just camara play there good, but what is caster? http://en.wikipedia.org/wiki/Caster_angle http://www.tpub.com/content/constructio ... 73_334.htm Link to comment Share on other sites More sharing options...
