cherokee Posted September 9, 2009 Share Posted September 9, 2009 have tried two different parts stores that had the exact same pulley that would not work because it locks solid to the dust cover/hub when the bolt is tightened down. Anyone know of a place to get a good a/c idler pulley? Link to comment Share on other sites More sharing options...
johnnyc Posted September 9, 2009 Share Posted September 9, 2009 I've read your post over and over again and still can't figure out what you're asking. One second you're talking about the A/C idler pulley. And then you mention a dust cover/hub. :???: :???: Are you talking about an A/C delete pulley and bracket? If so, I have one for a Renix sitting in my garage. Link to comment Share on other sites More sharing options...
jbhill Posted September 10, 2009 Share Posted September 10, 2009 stealer? Link to comment Share on other sites More sharing options...
akamcbird Posted September 10, 2009 Share Posted September 10, 2009 had the same issue. used a washer behind the univesal they sold me while i waited for the dealer unit, which was special order(to ak anyway) the universal was plastic, the dealer one was steel, and now i have a backup didnt have any problems with the belt lining up, don't remember what size washer i used i got an open box at schmucks and thaught it was spose to come with said washer Link to comment Share on other sites More sharing options...
cherokee Posted September 12, 2009 Author Share Posted September 12, 2009 I thought about a washer but didn't like the looks of how little of the hub would be supporting the bearing. Looks like I'll try the stealership next. Tried all 3 of the local parts places (Napa, CQ, Autozone) and they all tried to sell me the same plastic part. Link to comment Share on other sites More sharing options...
mvusse Posted September 12, 2009 Share Posted September 12, 2009 I had the same problem, twice (once each in MJ and XJ), and solved it by reusing the old pulley, and just replacing the bearing. It presses in and out quite easily, and is available from Tractor Supply (TSC) for less than $7. IIRC, the part number is 6305, but be warned there are two different bearings with that number. Both are the same thickness and outside diameter, but one has a 17mm (not quite 11/16, a bit bigger than 5/8) hole, and one has a 5/8. TSC sells both, make sure you get the right one. I'm pretty sure both my vehicles used the 17mm, but someone else on here is sure he needed 5/8. Link to comment Share on other sites More sharing options...
Mongo Posted September 12, 2009 Share Posted September 12, 2009 I just went to NAPA and got a new bearing pressed into original pully. Cost me around $8 Link to comment Share on other sites More sharing options...
