dancome433 Posted September 3, 2009 Posted September 3, 2009 has anybody run a 6in Hells Creek lift on their mj? I have an RRO lift that i havent installed yet, and would need to upgrade a bunch of stuff, might as well try to get a new lift, so lookin for options
HellCreek Posted September 3, 2009 Posted September 3, 2009 Hi, Our 6 inch lift is a Rough Country kit, which we have just started selling, so we have had no feedback on it yet. Your question should be," has anyone run a 6 inch Rough Country lift on their MJ?" We make 3", 4.5" and MT springs for MJs, but not 6". Thanks, Tom
dancome433 Posted September 3, 2009 Author Posted September 3, 2009 Cool, thanks man, how are the control arms setup? does it come with drop brackets or jus straight adjustable control arms
HellCreek Posted September 3, 2009 Posted September 3, 2009 The 6.5" lift is an SOA kit. It includes: 6.5" front coils drop pitman arm sway bar disconnects Adjustable upper and lower control arms T-Case drop Brake line drop brackets adjustable track bar rear SOA spring plate rear u-bolts rear adjustable shackles Hydro shocks LCA drop brackets, SYE kit, replacement drive shaft, Nitro shocks and SS brake hoses are all options. I really shouldn't be selling in the Tech section, but this is just info, and you asked. Thanks, Tom
dancome433 Posted September 4, 2009 Author Posted September 4, 2009 cool, yea its cool, I'm just getting info, its not like your selling anything
dancome433 Posted September 7, 2009 Author Posted September 7, 2009 what are you doing with the RRO lift? Upgrading, only thing I'm using out of the lift is the shocks, track bar, spring over perches for now until I get a different rear end and get other perches welded on and other little misc things that i can use. Whatever I don't use Ill sell. I already sold the drop brackets, going to upgrade to long arms, already replaced the 2.5 OME springs, 1in spacer and 2in spacer for 6in springs, still need to order extended brake lines, long arms, I think I'm going with Iron Rock, and JKS swaybar disconnects, buddy might have some i can get, and that should be about it, plus still need to get a driveshaft made
mnkyboy Posted September 7, 2009 Posted September 7, 2009 i might be interested in the springs and spacers,Did you get control arms in your kit?
BLHTAZ Posted September 7, 2009 Posted September 7, 2009 I am running the 3" Hell Creek leaf springs and love them :thumbsup: .
dancome433 Posted September 8, 2009 Author Posted September 8, 2009 i might be interested in the springs and spacers,Did you get control arms in your kit? I'm using the 2.5in springs right now to have a small lift to run my 31's, little rub at full turn but not too bad, but I'm not using the spacers if you want them, jus pm me about them and well make deal on them I am running the 3" Hell Creek leaf springs and love them :thumbsup: . cool, i was thinking of ordering the 3" rear springs to match up with the 2.5" front springs i have, to make a complete lift, but a 2in AAL and 1in extended shackle is doing ok for now,
BLHTAZ Posted September 8, 2009 Posted September 8, 2009 I am running the 3" Hell Creek leaf springs and love them :thumbsup: . cool, i was thinking of ordering the 3" rear springs to match up with the 2.5" front springs i have, to make a complete lift, but a 2in AAL and 1in extended shackle is doing ok for now, I have the 3.5" RE kit in the front; the 3" HC springs make it perfectly level..
