Getting it inspectable
hiya, finally really buckling down on getting the MJ inspected and driveable. problems are small but a pain.
-serpentine belt- haven't been able to find a good diagram, not really sure how to change one. (noob sorry still learning)
-back-up lights don't come one - checked fuses and such. was going to hook them up to a toggle switch. any other thoughts?
-speedometer- didn't work when i bought it, must be a bad cable or something?
any ideas of references on any of these things would be mucho appreciated.
My guesses for the backup lights could be either a bad switch on the trans, or a faulty connection in the main wire harness connector located right behind the rear drivers side tire. I've experienced both. :(
backup lights was a faulty connection. fixed that, beautiful.
the serpentine belt was interesting. loosened up the power steering pump and took it off. the old serpentine belt had sheared a rib (4 ribs in stead of 5) the alternator seems to be the problem here - someone put the wrong pulley on it. it has 4 ribs in stead of 5, so it sheared off a rib from the other belt. going to take a look at the alternator on the other MJ, see if I can use that, if not i'll get a new one.
the speedometer was easy. the cable was broken off from the back of the gauge. I guess i need to get a new cable. that should solve that problem. hopefully.
lot cheaper doing it yourself. :yes:
I also mounted my CB the other day, but haven't wired anything up yet, it actually fit into pre-drilled holes though.
also found a small army of mice when i took out my dash. and 8 or 9 baby ones too. shop vac cleaned that right up.
ah sorry, been neglecting the forums for a bit.
I went with one I knew would work with out any headaches, got one off of a 87 2wd from wildman.
after fiddling with both of them, I seriously doubt it would be plug and play. just see if you can pull one from a JY or something.
sorry.
