BCMJ87 Posted August 29, 2009 Share Posted August 29, 2009 My desktop puter is in the shop.. getting fixed, so I don't have access to my XJ/MJ repair files! I'm looking for dashboard lights layout.. has anyone got it or link to it online? Further, I have found a set of 1989 Full-size Waggy Dana 44's, probably not original axels, but the are a 6 bolt pattern! What would that pattern be called.. 6 on 4.5 or what.. I do think that they are a 16" wheel? Any assistance would be appreciated? Wheel-on.. BK Link to comment Share on other sites More sharing options...
Pete M Posted August 29, 2009 Share Posted August 29, 2009 The waggy pattern is 6 on 5.5". If you want to do a conversion to waggy axles, look into a mid 90s Isuzu rodeo rear axle. They have a Dana 44 diff, are the same 6on5.5 wheel bolt pattern, same width, and come with 4.10 or 4.30 gears and disk brakes. Then you'll only need to do a gear swap in the front to match. Oh, and swap on a regular U-joint yoke. :thumbsup: Link to comment Share on other sites More sharing options...
Darren Posted August 30, 2009 Share Posted August 30, 2009 I run a waggy 44 front. You can run a 15" wheel with them too, I do. Link to comment Share on other sites More sharing options...
