BCMJ87
    Oceanside BC Canada
  • Interests
    Offroading, mtn biking, camping & wrenching
BCMJ87's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. Hey tks for the interesting suggestion, I read the only review on the product and see that the final installed price is quite a bit more than advertised price of $169USD, closer to the 500USD mark. My main concern with that type of truss install would be the interference with over the knuckle crossover high-steer. Thank you though for the thought provoking suggestion!
  2. Here's the linx 4 ya just in case u need a set! http://www.ringpinion.com/ProductDetails.aspx?ProdID=3341
  3. See prior posting.. "Already built and ready to install"
  4. Sure 4cyl 589's Toyota killers! - even better combo when I put the 35's on. Cheers.. Bk
  5. I have also got my front Dana 44 built and ready to install.. the d44 came from a 1989 FSJ, Full size Wagoneer with front leaf springs! I'm looking forward to getting that front diff installed.. possible issues! - 89 FSJ has the 5.9L 360 V8 (future motor for this MJ) I anticipate a very stiff / rough ride with V8 leafs used in 4cyl application, I have plans to remove lowest leaf from the leaf-pac to soften up the ride and plans are to locate the axle aprox. 4" forward of stock coil spring location (enhanced approach angle). Question: Has anybody here the experience of front leaf spring installation in their MJ? I would be happy to hear any input or comments! Present Stance.. Photo, with d30 coil spring setup, plan is to have aprox. 1" higher than the rear once d44 is installed. Build on.. BK
  6. Updated: November 26, 2010 Changed front grill set to 1988 Jeep XJ Wagoneer. Finally got rear Dana44 built and installed.. 1988 XJ Dana 44, 1998 ZJ Grand Cherokee Discs and Rotors, 589's Detroit Trac Loc, 3/8 Armor Plate custom diff cover, wheel mounting space of 60".
  7. November 19th.. Sorry to take so long to get back to you Aaron, I think that your question may be answered in the photos one page back (pg.2) show the fender trim and further pix of that process can be found on my website http://stephenbrockfoster.com/jeep/index.htm cheers.. build on.. BK
  8. Nice look swb project.. best of luck and welcome :cheers:
  9. Happy Birthday CW.. I'm looking forward to see your bending idea's. Build on.. BK
  10. My desktop puter is in the shop.. getting fixed, so I don't have access to my XJ/MJ repair files! I'm looking for dashboard lights layout.. has anyone got it or link to it online? Further, I have found a set of 1989 Full-size Waggy Dana 44's, probably not original axels, but the are a 6 bolt pattern! What would that pattern be called.. 6 on 4.5 or what.. I do think that they are a 16" wheel? Any assistance would be appreciated? Wheel-on.. BK
  11. Sweet looking transformation there Don! Where did you find the windshield visor?.. I've heard that most mini truck visors will work.. gawd forbid.. one spec'd for a ranger? Keep up the great work.. kewl 4.6 BK
  12. Update: July 13, 2009 Been very busy with other things.. but I thought I would post up a recent photo! Keep Jeep'n on.. BK
  13. Hey cmelo, If u go to your autoparts store (NAPA) maybe, you can purchase a universal ebrake cable kit which comes with extra long cables that u install, synch up and cutoff the extra length then you don't have to source the cables through Jeep.. also much cheaper! Tks for the question.. BK
  14. July 02 - Pound the Pinch Seams after fender trim & Rear Spring Over Lift Pix as promised.. I'll only show my completed Pinch Seams after Pour15 & Paint.. The step photos are on my webstie.. Completed my rear Spring Over Conversion SOA Net lift aprox. 5.5" Stance is almost were I want it: waiting on: LCA drop brackets, adjustable UCA's, adjustable Drag Link and ACOS for the last couple of inches front lift. Hey, that's it for now.. tks 4x following my TREAD! BK
  15. Update: July 01, 2009 HAPPY :Canadaflag: CANADA DAY :huh???: Did my rear SOA today.. need to finish the front inner fenders and do the pinch seams.. maybe even add the 2" spacers till my ACOS come! Ill post up some pix shortly.. BK
