dunl Posted August 20, 2009 Share Posted August 20, 2009 So putting the kick plate back under the dash I figured I would look to see what these connectors were for. Can anyone help? Is the one on the right another light plug? Got this one covered. :) Link to comment Share on other sites More sharing options...
dasbulliwagen Posted August 20, 2009 Share Posted August 20, 2009 Stuff you don't have ! :yes: Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 20, 2009 Share Posted August 20, 2009 The third one down is for the headlight delay module. Link to comment Share on other sites More sharing options...
dunl Posted August 21, 2009 Author Share Posted August 21, 2009 Okay, that helps. As for things I don't have, why not get them? If the connections are there, I want to use them. It's easy enough to pull the courtesy lights from a Cherokee (I only got two, didn't realize there were more connectors underneath). Headlight delay module...is it possible to install, and where can I get one of those (specifically)? Clear plastic connector in between....any ideas on that one? Link to comment Share on other sites More sharing options...
jpdocdave Posted August 21, 2009 Share Posted August 21, 2009 you don't want the headlight delay, aslo called sentinal. it pisses me off, and i couldn't figure out why my headlights stayed on when i went to pick up my mj. all that happens is if you turn the headlights off after the ignition is off the lights stay on for a little while. i don't like it. wiring is under the dash for fog lights though, but the wiring is not there at the headlight harness, not too hard to install if you want. i just did it and some guys on here helped me out. Link to comment Share on other sites More sharing options...
dunl Posted August 21, 2009 Author Share Posted August 21, 2009 Wouldn't that sentinel keep you from leaving your lights on and killing the battery? I have some harness inside the engine compartment, on the driver's side behind the fuel ballast....on the Eliminator I sold, it looks like it goes into the driver's headlight area...is that a fog light harness? The Eliminator had them. Link to comment Share on other sites More sharing options...
jpdocdave Posted August 21, 2009 Share Posted August 21, 2009 if its a headlight harness that plugs in to the harness right after the balllist then it should be, its a 10 pin connector, if it had fog lights you can use that harness. that harness will have a relay for the fog lights in it. my opinion is make sure it all matches and just install that harness, instead of taking the fog light part out and splicing it into your truck. thats what i did and i kinda wish i just took the time to swap harnesses. Link to comment Share on other sites More sharing options...
Akula69 Posted August 22, 2009 Share Posted August 22, 2009 The white one is for the cruise control. Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 22, 2009 Share Posted August 22, 2009 Headlight delay module...is it possible to install, and where can I get one of those (specifically)? You can find the delay module on many Cherokees. As in the picture above, it's attached under the dash on the driver's side. Also get the blue chime module that will let you know if you left the lights on. See this post for more details viewtopic.php?f=4&t=12465 Link to comment Share on other sites More sharing options...
jpdocdave Posted August 22, 2009 Share Posted August 22, 2009 Headlight delay module...is it possible to install, and where can I get one of those (specifically)? You can find the delay module on many Cherokees. As in the picture above, it's attached under the dash on the driver's side. Also get the blue chime module that will let you know if you left the lights on. See this post for more details viewtopic.php?f=4&t=12465 ugh, hate the chime and i hate the delay module. i like simple, and i hate hearing buzzers. if you're dumb enough to leave your lights on, you will deal with it in the morining. :fool: Link to comment Share on other sites More sharing options...
