brdhntr Posted August 18, 2009 Share Posted August 18, 2009 there is no leaks and the fluid was flushed and filled last fall. the lines have been bled and there is no air in the line. this is a more recent problem that seems to be getting worse. there is no leaking at the master cylinder as well. the brakes do stop the truck, you just have to push the pedal way in. so, what do you think, bad master cylinder or booster? :dunno: Link to comment Share on other sites More sharing options...
bigd44889 Posted August 18, 2009 Share Posted August 18, 2009 ya i'd say master cyclinder is going or rear wheel cylinder and fluid is in the drumb were you can't see it yet Link to comment Share on other sites More sharing options...
project88mj Posted August 18, 2009 Share Posted August 18, 2009 the brake is the middle pedal not the left one :smart: jk maybe bad booster? :dunno: Link to comment Share on other sites More sharing options...
bigalpha Posted August 18, 2009 Share Posted August 18, 2009 I second bad master. If you swap out the master+booster, make sure you get the pushrod (the rod that connects booster to brake pedal) swapped out too, else you'll be scratching your balls with the brake pedal. Ask me how I know. Link to comment Share on other sites More sharing options...
maddzz1 Posted August 18, 2009 Share Posted August 18, 2009 Mine is doing something similar. No fluid leaking brakes are very soft and pedals goes to the floor. Brake light on dash comes on and stays on until i push the pedal down as far as i can then it goes off for a while. I am just gonna swap the booster and master for one from a 95-96 XJ, with those years you don't need to swap the push rod, just have to grind a flat edge into the round end. Link to comment Share on other sites More sharing options...
bigalpha Posted August 18, 2009 Share Posted August 18, 2009 Mine is doing something similar. No fluid leaking brakes are very soft and pedals goes to the floor. Brake light on dash comes on and stays on until i push the pedal down as far as i can then it goes off for a while. I am just gonna swap the booster and master for one from a 95-96 XJ, with those years you don't need to swap the push rod, just have to grind a flat edge into the round end. So the pushrod from my 88 is the same length as one from a 95-96? Link to comment Share on other sites More sharing options...
maddzz1 Posted August 18, 2009 Share Posted August 18, 2009 Mine is doing something similar. No fluid leaking brakes are very soft and pedals goes to the floor. Brake light on dash comes on and stays on until i push the pedal down as far as i can then it goes off for a while. I am just gonna swap the booster and master for one from a 95-96 XJ, with those years you don't need to swap the push rod, just have to grind a flat edge into the round end. So the pushrod from my 88 is the same length as one from a 95-96? Just the end is shaped different (the end of the 95-96 is round). So you grind part of it flat. Scroll down to the brake booster upgrade and then scroll down to the yellow part of that page: http://www.madxj.com/ Link to comment Share on other sites More sharing options...
bigalpha Posted August 18, 2009 Share Posted August 18, 2009 Luckily, I got the master and booster for free, so I just need to get the push-rods swapped. Does it take a specialized place to do that? Link to comment Share on other sites More sharing options...
brdhntr Posted August 19, 2009 Author Share Posted August 19, 2009 ya i'd say master cyclinder is going or rear wheel cylinder and fluid is in the drumb were you can't see it yet i checked for that. no leaking in the drums or at the calipers Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 19, 2009 Share Posted August 19, 2009 Hope this helps, from the '90 FSM. Link to comment Share on other sites More sharing options...
