navigator Posted August 17, 2009 Share Posted August 17, 2009 ok, i hadn't noticed this until I got new tires but my drivers side front wheel looks to be sitting out about an inch further than the other tires. it almost looks like a wider rim or something. All the other tires are pretty much flush with the body but the driver side front tire looks to be out about an inch, maybe more. Everything drives fine except there is a little play in the steering wheel. TRE's all seem ok. Any ideas? Link to comment Share on other sites More sharing options...
Pete M Posted August 17, 2009 Share Posted August 17, 2009 any lift? Link to comment Share on other sites More sharing options...
navigator Posted August 17, 2009 Author Share Posted August 17, 2009 no, completely stock. 235/75/15 tires, aluminum stock jeep wheels. Link to comment Share on other sites More sharing options...
Pete M Posted August 17, 2009 Share Posted August 17, 2009 interesting. Technically, both front tires should stick out a little bit. The MJ is wider in the bed area than the front. Have you had someone saw the wheel back and forth while you watched the frontend? Check for play in the bushing on the other end of the trackbar, as well as movement of the trackbar bracket relative to the frame, and also look for a crack in the frame between the steering gear and the trackbar bracket. Link to comment Share on other sites More sharing options...
navigator Posted August 17, 2009 Author Share Posted August 17, 2009 will do, my passenger side front fender was banged up a little due to my nephew hitting a deer with it before I got it but I pulled it out where you don't notice it, maybe it is actually pulled out more than it should be. I was more lining it up with the rear wheels. I might measure from the inside of the wheel to something underneath for a starting point and get someone to rock the steering wheel back and forth a few times so i can see what might be going on. thanks for the responses, i'll try to post back my findings. Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 17, 2009 Share Posted August 17, 2009 Actually the front track and rear track (distance between the wheels) is the same on MJs if all four wheels are the same width. But because the rear bed fender wells are about 2" wider than the front, it looks like the front wheels stick out farther than the rear. If your front axle has shifted to the left it's most likely a lot of slop in the track bar. Link to comment Share on other sites More sharing options...
navigator Posted August 18, 2009 Author Share Posted August 18, 2009 there is a good amount of play in the steering when driving. Say you are driving straight and have the steering wheel at 12 o'clock, you would have to go to say 11 o'clock to go left or 1 o'clock to go right, then the steering is good. Could that be related? Link to comment Share on other sites More sharing options...
Pete M Posted August 18, 2009 Share Posted August 18, 2009 yes, it could be. The track bar centers the axle left to right. If any part of that bar or its bracket are sloppy, it could result in both issues you're experiencing. Link to comment Share on other sites More sharing options...
twojeeps Posted August 18, 2009 Share Posted August 18, 2009 I have Grand Cherokee wheels on my 88 MJ 2wd.... when I had new tires put on we noticed a spacer behind the front wheels..... the PO must have installed to give clearance for the center cap when putthing those wheels on........ therefore both of my front tires stick out further than the rear Link to comment Share on other sites More sharing options...
bigd44889 Posted August 18, 2009 Share Posted August 18, 2009 said it was hit maby bent track bar or bent unirails in the front Link to comment Share on other sites More sharing options...
navigator Posted August 18, 2009 Author Share Posted August 18, 2009 it was low speed with a deer, the grill and bumper caught most of the damage. Thanks for all the responses, i have a few things to look into now. Link to comment Share on other sites More sharing options...
