Guest gogetemturbo Posted August 28, 2006 Share Posted August 28, 2006 Lifted my rig yesterday. Used Rubicon Express 4.5" coils w/ upper and lower adj. arms. SPOA in the back and installed my D44 w/ 4.10s. Put on some 33x12.5x15 BFG ATs w/ black steelies. Looks awesome! Image Not Found Image Not Found I'll get some wheelin pics soon I hope. I'll also keep you all informed on the 4x2 to 4x4 conversion and the install of an '01 XJ 4.0L into the truck. Complete with dash and center console. Swap should be happening here in a couple few weeks. :D Link to comment Share on other sites More sharing options...
Guest Posted August 29, 2006 Share Posted August 29, 2006 got any side shots Link to comment Share on other sites More sharing options...
Oizarod115 Posted August 30, 2006 Share Posted August 30, 2006 gogetemturbo said: I'll also keep you all informed on the 4x2 to 4x4 conversion :D I'm guessing you've already done the front axle part of the 4x4 conversion? or are you re-doing what someone un-did? Link to comment Share on other sites More sharing options...
Guest Posted August 30, 2006 Share Posted August 30, 2006 This is the best one I got right now. I'll take some better ones this week-end. Image Not Found And Yes, I have already done the front axle part of the swap. :D And the tranny and t-case will go in when I do the motor swap. Not much point in unbolting everything just to unbolt it again! But after that then it's smooth sailing! :driving: :D Link to comment Share on other sites More sharing options...
Oizarod115 Posted August 30, 2006 Share Posted August 30, 2006 how much backspacing do your rims have? w (that thing sits perfectly level! :popcorn: ) Link to comment Share on other sites More sharing options...
feerocknok Posted September 1, 2006 Share Posted September 1, 2006 Oizarod115 said: (that thing sits perfectly level! :popcorn: ) That's the way, uh-huh, uh-huh, I like it! Link to comment Share on other sites More sharing options...
minydigger Posted September 1, 2006 Share Posted September 1, 2006 What is the length of your lower arms and were the adj. uppers needed or what? Link to comment Share on other sites More sharing options...
gogetemturbo Posted September 4, 2006 Share Posted September 4, 2006 Not sure on the backspacing, got them from a buddy and I didn't measure them before I put them on. I would venture to guess that they are 4.5" or so. The lower arms are at 17" from center bolt to center bolt. The upper adjustables arm definatly needed! I set it down with them at stock length first and the blasted thing was ridiculous! I don't remember off hand what the measurment came out for the upper, I just know that the caster angle is good. Link to comment Share on other sites More sharing options...
trailnfish Posted June 15, 2019 Share Posted June 15, 2019 How long did it take you? I know this is very old Link to comment Share on other sites More sharing options...
Pete M Posted June 16, 2019 Share Posted June 16, 2019 On 6/15/2019 at 3:45 AM, trailnfish said: How long did it take you? I know this is very old Expand he hasn't been on here in 3 years. you could try sending a private message. he should get an email alert about that. Link to comment Share on other sites More sharing options...
trailnfish Posted June 16, 2019 Share Posted June 16, 2019 On 6/16/2019 at 9:35 PM, Pete M said: he hasn't been on here in 3 years. you could try sending a private message. he should get an email alert about that. Expand Thanks, Pete. Link to comment Share on other sites More sharing options...
