SchneiderFishing Posted July 14, 2009 Share Posted July 14, 2009 I was wondering what the opinion on shocks is. I've got a 1990 Comanche Long Bed 4.0 I am using it to tow a 21 foot bass boat. It seems to drop quite a bit when I put the trailer on. I have no idea how old the shocks are. Any thoughts on the best shocks for my situaton? Link to comment Share on other sites More sharing options...
mnkyboy Posted July 14, 2009 Share Posted July 14, 2009 sounds like your problem is the springs not the shocks. I would get helper springs or air bags Link to comment Share on other sites More sharing options...
SchneiderFishing Posted July 14, 2009 Author Share Posted July 14, 2009 Could be. Any suggestions on helper springs? Link to comment Share on other sites More sharing options...
mnkyboy Posted July 14, 2009 Share Posted July 14, 2009 theres a few different types of helpers,and i havent really messed with them much. hopefully someone will chime in that has more experience with them. Link to comment Share on other sites More sharing options...
SchneiderFishing Posted July 14, 2009 Author Share Posted July 14, 2009 As I do a little online reading I tend to agree that the helper springs should be the way to go. Hopefully I'll get someone with some experience to chime in. Thanks. Link to comment Share on other sites More sharing options...
Wildman Posted July 15, 2009 Share Posted July 15, 2009 I would 2nd the air bags as helper springs, with you towing a boat, the advantage of the air bags is you can increase the air pressure with the tow load, and when your done towing, air down the bags to give you a more comfort ride. http://www.autoanything.com/brands/102A487.aspx Plus some of the "add" on helper springs don't work that will, and put alot of added stress on your 20 year old tired leafs :eek: I've seen leafs broken from helpers, and seen help springs also break. The cost of the air bags are under $90, with out the OBA system, and the advantage is you can take them off and transfer them to another MJ if your replace your current one. Link to comment Share on other sites More sharing options...
Geonovast Posted July 15, 2009 Share Posted July 15, 2009 I'd track down a new set of Metric Tonne springs. Link to comment Share on other sites More sharing options...
HellCreek Posted July 15, 2009 Share Posted July 15, 2009 Geonovast said: I'd track down a new set of Metric Tonne springs. We have those for sale. :thumbsup: We are also introducing add-a-leaves specifically made for Comanches. They are basically main leaves without the eyes. We are also introducing the longer second stage leaves from the Metric Tonne springs to add to your existing spring pack above the standard second stage leaf. These would practically convert your existing springs into a Metric Tonne set. -Tom Link to comment Share on other sites More sharing options...
SchneiderFishing Posted July 15, 2009 Author Share Posted July 15, 2009 Do you have a web link for those Metric Tonne springs? Link to comment Share on other sites More sharing options...
HellCreek Posted July 15, 2009 Share Posted July 15, 2009 www.hellcreeksuspensions.com/springs/Springs.aspx. Just select JEEP using the forward or previous buttons, then scroll down the drop-down list until you see MJ Comanche Metric Tonne, select that, then the year. The part number button will then appear. Click that and you will be taken to the shipping calculator page. OR you can call me at (662) 534-2216. -Tom Link to comment Share on other sites More sharing options...
