4play Posted August 20, 2006 Posted August 20, 2006 I seem to have developed a leak on an injector: The arrow shows where the leak appears to be. Are these repairable? Or just replacable? I have a spare truck with complete motor. (Looking for the cheapest fix of course :roll: )
Cabz Posted August 20, 2006 Posted August 20, 2006 Replaceable only , while you have it off do all the orings , It will save you from havein to pull it off again
Pete M Posted August 20, 2006 Posted August 20, 2006 Yup, the O-rings are replaceable. You might take the opportunity to soak the ends in something to clean out the ports.
ORCA Posted August 20, 2006 Posted August 20, 2006 Yup, the O-rings are replaceable. You might take the opportunity to soak the ends in something to clean out the ports. Like what? Carb cleaner? (I might be doing this soon...)
Oizarod115 Posted August 21, 2006 Posted August 21, 2006 when i did it i bought new injectors (set of 6) from five-o motorsport and they came with new o-rings on them, just pulled the fuel rail off the old ones, pulled them out, tossed them out, vasolined the o-rings (to make it easier to pop them in) put them in put the clips back on that hold the connectors on, and put the fuel rail back on.... viola! real easy... just expensive.
Bounty Hunter Posted August 21, 2006 Posted August 21, 2006 Soaked mine in carb cleaner (just the tips). Your leak is repairable if the leak is from an o-ring line mine was. If it's from the injector body, you'll have to replace the injector. The FSM says to remove and install the injectors as one with the fuel rail, which is how I did it.
