AaronClarsen Posted June 11, 2009 Posted June 11, 2009 So i was taking off from a stop light (a little fast) the other day and my right side motor mouth broke off.. it looks like the mount is still okay,, just the bolts where sheared off flush with the block.. so i have to get thouse out and reattach the motor mount... but here is the thing.. when i heard it break i pulled over right... and there was oil all over my front end... so like... something broke..and i don't think it is the block...do you have any ideas? Â I towed it home.. and we started it again and no oil looks to be dumping out... so i don't get it..
Geonovast Posted June 11, 2009 Posted June 11, 2009 I would bet you broke or bent the oil filter adapter, or put a crack in the oil pan.
Wildman Posted June 11, 2009 Posted June 11, 2009 I would bet you broke or bent the oil filter adapter, or put a crack in the oil pan. Â Â X2 Â After you get the mount re-attached to the engine, do a very good check on the oil filter adapter, and check the oil pan out really well. If your lucky, you might have just punched a hole in the oil filter........if not, good chance you punched a hole in the oil pan :eek:
BLHTAZ Posted June 12, 2009 Posted June 12, 2009 I would bet you broke or bent the oil filter adapter, or put a crack in the oil pan. Â Â X2 Â After you get the mount re-attached to the engine, do a very good check on the oil filter adapter, and check the oil pan out really well. If your lucky, you might have just punched a hole in the oil filter........if not, good chance you punched a hole in the oil pan :eek: I concur with the previous two responses :thumbsup:
AaronClarsen Posted June 19, 2009 Author Posted June 19, 2009 Well i think i got really lucky and it was just the oil filter... so that was exciting. and today i got the bolts out of the block, and yep.. things are looking upp
Wildman Posted June 19, 2009 Posted June 19, 2009 Yes you did :yes: Â You dodged a big bullet with just punching a hole in the oil filter :thumbsup: Â Lets see........oil filter $5.........oil pan and gasket $120 :doh:
AaronClarsen Posted June 19, 2009 Author Posted June 19, 2009 lol yes =) i can't wait to put her all back together tomorrow
reson46 Posted June 19, 2009 Posted June 19, 2009 Have you determined why the stock bolts broke? Were they in pretty bad shape? I know some have had problems with the stock block mounts, but usually those are in some pretty extreme situations. Â Willy
AaronClarsen Posted June 20, 2009 Author Posted June 20, 2009 Well only one bolt was still in, it just broke 2, the one that was left in it was very bent tho, but by the time we drilled and used easy outs on the remaining bolts.. you couldn't tell nothing. so no. don't know why.... but i hold these new ones hold...
aemsee Posted June 20, 2009 Posted June 20, 2009 I have seen many mount bolts broken on stock Cherokee's over the years. Could be a combination of low quality bolts and too much torque when being tightened.
aemsee Posted June 20, 2009 Posted June 20, 2009 Make sure you do a good check on the oil pan where it juts out on the pass side. That is where the oil pump is. I have seen numerous cases of the pass side UCA mount hitting the pan, denting it in and cracking the oil pump without puncturing the pan.
AaronClarsen Posted June 21, 2009 Author Posted June 21, 2009 Make sure you do a good check on the oil pan where it juts out on the pass side. That is where the oil pump is. I have seen numerous cases of the pass side UCA mount hitting the pan, denting it in and cracking the oil pump without puncturing the pan. Â Â wait so do i have to take the oil pan off to look at that?
Geonovast Posted June 21, 2009 Posted June 21, 2009 Yes, the oil pump is inside the pan. Â Do you have a pressure gauge?
aemsee Posted June 22, 2009 Posted June 22, 2009 Just look at the pan to see if there is a dent there. No dent, no worry.
