conan1977 Posted June 8, 2009 Posted June 8, 2009 Hello and good afternoon guys. I need some assistance. I broke a bolt off of my girlfriends 99 Cherokee (XJ) today. The bolt was located on the back rear shock (upper mounting bolt), they are rusted like a none other. Anyway, I was wondering what is the easiest way to get it out (I have limited tools--but tons of redneck knowledge). I am pretty sure the other will break as well. I just need some assistance and you guys have been more than helpful in the past. I love this website and you guys help keep my Comanche moving. Thanks a ton. Conan
Geonovast Posted June 8, 2009 Posted June 8, 2009 The best way to do it is to drill a hole in the bolt, heat it up, and pull it out with an easy-out. Then drill out the old threads and re-tap it to the next biggest size.
aemsee Posted June 8, 2009 Posted June 8, 2009 Or....use a hefty long punch and a BFH and break the spot welds holding the nut to the rear crossmember section, then use some thin wire to fish a grade 8 bolt with a washer through the hole(s) and use a nut w/ washer at the shock. I couldn't count how many timess I've done that. Common problem.
Pete M Posted June 8, 2009 Posted June 8, 2009 I think this is what he's referring to: http://www.jeepforum.com/forum/showthread.php?t=323809
aemsee Posted June 8, 2009 Posted June 8, 2009 BINGO! Thanks Pete ( I use a piece of wire instead of the magnet.)
