88mjmanche Posted June 5, 2009 Posted June 5, 2009 so they say that going from 3.07-3.73 ratios to 4.10-4.88 ratios you "need" :smart: to buy the low ratio carriers. i don't know a hole lot about this so if you could tell me why you need the low ratio carrier that would be nice. and also can you go from 3.07 like me to 4.56 and be alright with out the low ratio carrier :dunno:
Geonovast Posted June 5, 2009 Posted June 5, 2009 The two carriers are different. I believe the low ratio flange is bigger and closer to the pinion. 3.07-3.73 gears will not go on a 4.10-4.88 carrier, and vice-versa. You need the proper carrier.
mjeff87 Posted June 5, 2009 Posted June 5, 2009 because as the ratio gets deeper, the pinion gear gets smaller. Like Genovast said, that increases the space between it and the ring gear. The carrier is thicker to make up the distance and gain proper gear face engagement. Some axles have "thick cut" gears available for them, and you can use the original carrier (the thickness of the ring gear makes up the difference) Jeff
reson46 Posted June 9, 2009 Posted June 9, 2009 It is referred to as the carrier break. The break is entirely dependent upon the axle. - For example, the Ford 8.8 does not have a carrier break. - If I remember correctly the D30 breaks between 3.55 and 3.73. So 3.55 and up uses a different carrier than 3.73 and down. Willy
reson46 Posted June 10, 2009 Posted June 10, 2009 can i put 3.73 on a 307 carrier Entirely depends upon where the carrier break is for the axle. What axle do you want to regear? Willy
mjeff87 Posted June 10, 2009 Posted June 10, 2009 I don't have the link handy, but check Yuccaman's website....he has an excellent page on it with complete details on several different axles, front and rear, including carrier breaks for all of them. Jeff
88mjmanche Posted June 12, 2009 Author Posted June 12, 2009 both my dana 30 to 3.73 and my dana 44 to 3.73
reson46 Posted June 12, 2009 Posted June 12, 2009 both my dana 30 to 3.73 and my dana 44 to 3.73 For the D30... - If I remember correctly the D30 breaks between 3.55 and 3.73. So 3.55 and up uses a different carrier than 3.73 and down. From a quick Google search it looks like I was correct on this. You will need the lower carrier to regear the D30 to 3.73. The D44 carrier break is between 3.73 and 3.92. Your current carrier will be fine with the 3.73 gears. Also found a couple other carrier breaks and other tech info here. Willy
Pete M Posted June 12, 2009 Posted June 12, 2009 both my dana 30 to 3.73 and my dana 44 to 3.73 I'd go with 4.10s. :thumbsup:
88mjmanche Posted June 16, 2009 Author Posted June 16, 2009 yea but if i put in 4:10 gears i will have to get low ratio carriers right
reson46 Posted June 16, 2009 Posted June 16, 2009 yea but if i put in 4:10 gears i will have to get low ratio carriers right Compared to setting up gears, carriers are cheap. You already need a carrier for the D30. Why spend all that money on something that you may not be happy with in the end? Willy
smithe1811 Posted June 21, 2009 Posted June 21, 2009 Sooooo, my parts truck has 3:55 and my DD has 3:07, both are d30/d35, can i just take the whole assembely carrier and all from the 3:55 axles and put them in place of my 3:07's? rather than swaping the whole axle over?
smithe1811 Posted June 21, 2009 Posted June 21, 2009 Do you know how to properly set up gears? i do not, i wa just hoping for an easy way to upgrade but I'm guessing thats not it.
Pete M Posted June 21, 2009 Posted June 21, 2009 Sorry. :( Installing gears is just one of those things that takes more skill/tools than the average wrench-turner has. And it costs a lot to have a pro do it. Swapping axles is usually more cost effective as long as you're staying within stock gear ratios.
88mjmanche Posted June 21, 2009 Author Posted June 21, 2009 nope :D and also just wondering will a jeep willies d 44 ring & pin. match to my d 44 :dunno:
