smithe1811 Posted May 11, 2009 Share Posted May 11, 2009 Well, when i started tearing into my parts pig i found these two hoses and I'm not sure what they are for, they go from the radiator to the tranny(aw4), are they part of the heavy duty cooling system? the truck had both cooling fans in it. also if they are a useful part, will they work on a ba-10/5? its the two smaller ones at the top and bottom of the rad Image Not Found here they are running from the right Image Not Found pic from the front of the two running to the back, they go right ointo the side of the tranny pic of my DD setup Image Not Found Link to comment Share on other sites More sharing options...
dasbulliwagen Posted May 11, 2009 Share Posted May 11, 2009 Yes those are tranny cooler lines for an automatic trans only. Not sure if part of a heavy duty package or not. Most auto trans have them. They will not work for a BA-10/5 as they are not needed. If you are converting to manual, just disconnect them and put plugs over the rad ports so nothing can get in there. Link to comment Share on other sites More sharing options...
smithe1811 Posted May 11, 2009 Author Share Posted May 11, 2009 Thank you once again i just wanted the electric fan from it. Link to comment Share on other sites More sharing options...
smithe1811 Posted May 11, 2009 Author Share Posted May 11, 2009 Does anyone have a good pic or write up on how the factory electric fan is installed? I'm looking in the FSM and the elec manual and its not really helping me here. i know alot of guys are puting their fan on a seperate switch but i just want to hook it up the factory way for now so any help here would be GREAT! Link to comment Share on other sites More sharing options...
mvusse Posted May 12, 2009 Share Posted May 12, 2009 If that radiator is going into a truck with a manual gearbox, you can always use the tranny cooler or either an oil cooler, running your engine oil through it, or a power steering cooler. Link to comment Share on other sites More sharing options...
smithe1811 Posted May 12, 2009 Author Share Posted May 12, 2009 how would i do that? if were to use if for an oil cooler? Link to comment Share on other sites More sharing options...
OSHAGNASTY Posted May 12, 2009 Share Posted May 12, 2009 tranny cooler Link to comment Share on other sites More sharing options...
Lemmon714 Posted May 13, 2009 Share Posted May 13, 2009 I took a look at my 87. There are two factory connections from the "Lighting Harness" in your picture- a red and black wire for the fan power and a gray and yellow wire from the same harness that plugs into the "Open port" above the radiator hose. The fan mounts in the open tabs at bottom and the two screws at the top. I don't have an electrical schematic to look at to see if there are other requirements. I am not sure if I would use the radiator for a power steering cooler. At 210F it would seem like you might be heating the power steering fluid instead of cooling it. All the power steering coolers I have seen are self contained to the PS pump and hoses. Link to comment Share on other sites More sharing options...
Pete M Posted May 13, 2009 Share Posted May 13, 2009 Why would anyone need an engine oil or manual trans oil cooler? Last I checked, the oils we put into them are designed to be at a certain temperature, not cooler. It's bad enough that an auto trans has those weak little fluid lines running around just waiting to fail, I wouldn't want that with my engine oil too. :ack: Link to comment Share on other sites More sharing options...
