chunks6067 Posted April 26, 2009 Share Posted April 26, 2009 ok so my cousin has a 2.5 that shows symptoms of a bad alternator and she asked me to replace it anybody know how hard it is to take it off and on (time/ difficulty/ tools)? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 26, 2009 Share Posted April 26, 2009 ok so my cousin has a 2.5 that shows symptoms of a bad alternator and she asked me to replace itanybody know how hard it is to take it off and on (time/ difficulty/ tools)? year? it's pretty much the same process any year... loosen power steering pump (pretty much same process as doing a 4.0's p/s pump), remove belt(s), disconnect battery, unbolt terminals from alternator (similar location to the 4.0 alternator), unbolt several bolts/nuts, remove, replace, reverse order. the only real difference is between 86 and 87 when they changed over to Serpentine belts. Basically, you have to take off more belts with a V belt assembly. here's the too differences Link to comment Share on other sites More sharing options...
chunks6067 Posted April 26, 2009 Author Share Posted April 26, 2009 year? its not a older than a 90 so 91 and up not sure up until when they mad the 2.5 as i am completely unfamiliar with them Link to comment Share on other sites More sharing options...
Geonovast Posted April 26, 2009 Share Posted April 26, 2009 year? its not a older than a 90 so 91 and up not sure up until when they mad the 2.5 as i am completely unfamiliar with them 2.5 was made every year of the XJ and MJ. Link to comment Share on other sites More sharing options...
WBKrazy Posted April 26, 2009 Share Posted April 26, 2009 it's very easy, i just did mine 2 days ago, and it took me about 40 mins total.... the job becomes much easier if you take the battery out... the p/s pump bolts are all 13mm, the tensioner is 14mm, the upper alt. bolt is 15mm, the lower alt. bolt is 13mm and there's a 13mm nut on the backside of it, and the charge wire on the back of the alt. is a 3/8. Link to comment Share on other sites More sharing options...
