87manche Posted October 21, 2005 Share Posted October 21, 2005 so, is my 87 supposed to have a 4wd light on he dash? I shift to 4wd and I get no indicators. $WD is engaged, I found a gravel parking lot and spun a tire on both axles. Man, I wish I could find a manual Link to comment Share on other sites More sharing options...
DirtyComanche Posted October 21, 2005 Share Posted October 21, 2005 There's a sensor under the coolant resivoir bottle, bolted to the fender, if memory serves. The dash light might be burned out. And yeah, they all got them, if it is 4wd, I think. Link to comment Share on other sites More sharing options...
87manche Posted October 21, 2005 Author Share Posted October 21, 2005 ok, I'll find the sensor and check that. then move onto the dash light. Thanks for the info DC. this place is great. Link to comment Share on other sites More sharing options...
512tr Posted October 21, 2005 Share Posted October 21, 2005 so, is my 87 supposed to have a 4wd light on he dash?I shift to 4wd and I get no indicators. $WD is engaged, I found a gravel parking lot and spun a tire on both axles. Man, I wish I could find a manual You can download a pdf manual from Yahoo Comanche Club. http://autos.groups.yahoo.com/group/jeepcomanche/files/ It's the Ovner Manual for a 1990 mod :) Link to comment Share on other sites More sharing options...
Bounty Hunter Posted October 21, 2005 Share Posted October 21, 2005 Check the 3rd vacuum connection at the front axle disconnect, it's the one that signals the 4wd light. Link to comment Share on other sites More sharing options...
87manche Posted October 21, 2005 Author Share Posted October 21, 2005 thanks for the info fellas. I'll look into the vacuum line for blockage and such. I take it the sensor in the engine compartment is the vacuum switch? Link to comment Share on other sites More sharing options...
Bounty Hunter Posted October 21, 2005 Share Posted October 21, 2005 It's a vacuum operated switch. Vacuum operates the front axle disconnect, and this switch detects the disconnect is engaged via vacuum from the disconnect. The switch then activates the dash light. Newer jeeps have an electric 4wd switch right at the front axle disconnect. Link to comment Share on other sites More sharing options...
87manche Posted October 22, 2005 Author Share Posted October 22, 2005 well, I crawled under there last night, it looks like a PO replaced that vacuum line to the axle and just didn't bother hooking up the switch. I'll have to figure out how to hook it back up when it's daylight. Link to comment Share on other sites More sharing options...
cjharr Posted December 13, 2005 Share Posted December 13, 2005 so, is my 87 supposed to have a 4wd light on he dash?I shift to 4wd and I get no indicators. $WD is engaged, I found a gravel parking lot and spun a tire on both axles. Another possibility is the 4wd vac switch on the xfercase (as I found out replacing vac lines) when my light would only stay on constantly. The switch was approx $15 from Orielly Auto.( Hint: Use Orielly, Advance Auto, Partsamerica, or Autozone against each other for the best price on anything that you have to buy from them. Just make sure the part numbers match up) Link to comment Share on other sites More sharing options...
87manche Posted December 13, 2005 Author Share Posted December 13, 2005 well, I'm pretty sure that the light is just burnt out. Quite frankly it doesn't bother me that much. I know when I've pulled the t-case handle, and I don't park in 4WD. I only use the 4wd in dire situations anyway. I'd prefer to just drive in 2WD all the time. I've got to take the dash apart to fix the heater controls and install a new radio soon. I'm gonna take that extra step and replace all the lights. Link to comment Share on other sites More sharing options...
Frankensteinsmj Posted December 14, 2005 Share Posted December 14, 2005 mine don't come on either so I guess your not the only one. :( Link to comment Share on other sites More sharing options...
pingpong Posted December 14, 2005 Share Posted December 14, 2005 I think I have a few of thos vacum switchesd in the shed, along with a VD actuator or 2. Patrick Link to comment Share on other sites More sharing options...
