dakal Posted April 10, 2009 Share Posted April 10, 2009 this is a 1988 4.0 renix. someone put in a ax-15 :D . there are 2 sets of wires coming from it. 1st set: on passenger side of trans a removable plug with two wires. 2nd set: two wires coming from top of transmission. what are they for? which ones are which clutch start switch? shift lite? THANKS AGAIN Link to comment Share on other sites More sharing options...
Pete M Posted April 10, 2009 Share Posted April 10, 2009 1st set: on passenger side of trans a removable plug with two wires. I believe that one is the backup light. Link to comment Share on other sites More sharing options...
jtdesigns Posted April 10, 2009 Share Posted April 10, 2009 Would one be the 5th gear switch that turns off the shift light? Link to comment Share on other sites More sharing options...
IDXJ Posted April 11, 2009 Share Posted April 11, 2009 The plug on the right side is the reverse light switch. Not familiar with one on top. Link to comment Share on other sites More sharing options...
Giffer Posted April 11, 2009 Share Posted April 11, 2009 the top is the crank position sensor if I'm following you correct. is there like a 2 inch oval hole?? Link to comment Share on other sites More sharing options...
dakal Posted April 11, 2009 Author Share Posted April 11, 2009 no, these two wires come from below, circle around the trans then go up to where i can't see them. i can take a pic tomorrow. Link to comment Share on other sites More sharing options...
