countrycomanche Posted April 1, 2009 Posted April 1, 2009 I'm considering buying a 87' MJ but its got a busted Rear driveshaft. All the junk yards around here say they don't have the shaft. Could I possibly find one off an xj. I understand that the shaft length depends on a lot of things, but is there a direct fit off any XJ
Geonovast Posted April 1, 2009 Posted April 1, 2009 XJ shafts are considerably shorter. You MAY get lucky with a 4cyl 2wd XJ shaft fitting in a 4wd swb MJ, but I'm not sure about that. You'll have to get measurements. What's busted on yours? You may be able to get it retubed.
Pete M Posted April 1, 2009 Posted April 1, 2009 Or if one of the yokes is broken, grab a rear driveshaft from an XJ and get that one retubed to the proper length. Or find one from a 2wd MJ and have it shortened. The only limitation here is finding a driveshaft with yokes that accept the proper sized U-joints. Then get it retubed or shortened. Plenty of vehicles will have the right sized yokes. :thumbsup:
Tomahawked Posted April 1, 2009 Posted April 1, 2009 If tube isnt bent just take to a driveshaft shop and have the end replaced.
tmmoll Posted April 6, 2009 Posted April 6, 2009 If you go to a driveshaft shop, they may be able to repair the broken one or build you a new one for around $100.
Automan2164 Posted April 7, 2009 Posted April 7, 2009 Would this jeep be in the Janesville, Wi area? Rob L.
Geonovast Posted April 7, 2009 Posted April 7, 2009 Would this jeep be in the Janesville, Wi area? Rob L. If it is I have several shafts sitting around...
Automan2164 Posted April 7, 2009 Posted April 7, 2009 I knew i should have asked on the board... Nah only reason i asked is because i just picked up my MJ out of janesville, and one of the stipulations was it had a two piece driveshaft that was supposed to be a one piece. :fs1: I just had a local drivetrain shop make me a new one... Oh well. I have pics to post of the new horse, just can't get them on... If only my 10 year old digital camera and my brand spanking new laptop could speak the same language. :shake: Rob L.
Geonovast Posted April 7, 2009 Posted April 7, 2009 I knew i should have asked on the board... Nah only reason i asked is because i just picked up my MJ out of janesville, and one of the stipulations was it had a two piece driveshaft that was supposed to be a one piece. :shake: Rob L. Wait, what? That wasn't a factory option. If you figure out how to get the camera to cooperate and take some pictures that would be awesome.
Pete M Posted April 7, 2009 Posted April 7, 2009 By "2-piece", I think he means the rubber isolator version.
Automan2164 Posted April 7, 2009 Posted April 7, 2009 By two piece i mean the custom installation of 20 years of rust and that ever so slight application of "too much torque" :doh: The PO twisted it in to and nursed it home on the front shaft. Rob L.
