jtdesigns Posted March 18, 2009 Share Posted March 18, 2009 the rear lower control arms on the geo tracker 90-99, suzuki sidekick, and chevy tracker, all 90-99, are 2 inches longer than the xj front control arms, and will fit directly, with a little love. they are round stock, and torque pretty good. Link to comment Share on other sites More sharing options...
Geonovast Posted March 18, 2009 Share Posted March 18, 2009 That may be true, but I believe there's no bend to them, which will limit your downtravel. Link to comment Share on other sites More sharing options...
wolfpackjeeper Posted March 18, 2009 Share Posted March 18, 2009 not sure about the downtravel bit, long arms are strait. You will rub against them at full lock. Being strait instead of bent may affect the arc the axle swings in... Link to comment Share on other sites More sharing options...
DirtyComanche Posted March 18, 2009 Share Posted March 18, 2009 not sure about the downtravel bit, long arms are strait. You will rub against them at full lock. Being strait instead of bent may affect the arc the axle swings in... Downtravel is limited by control arm angle (among other things) - after a certain point they bind on the coil bracket. Long arms aleviate this problem as the angle change of the arms is less. A bent arm does not affect the arc the axle swings on. Only the position of the bolts (pivot points) for the arms affect that, with a certain amount of error based on bushing and link deflection. But I'd ask what good a 2" longer LCA is? Unless a guy wants to extend the wheelbase about 2" and make some UCAs to match. At which point I think a guy would be better off making new LCAs and UCAs. Link to comment Share on other sites More sharing options...
