95whitetrash Posted February 26, 2009 Posted February 26, 2009 Okay guy's, what vehicle can I get a front axle out of that will bobuying lt up to my 1986 MJ . I am buying this mj and the front axle has been changed to a two wheel drive axle and i want to put it back to four wheel drive. I know i need to make sure the new axle has the same gear ratio but I am stumped as to which axle will fit many thanks in advance. :fool: sorry it's a 1986 XLS with the GM V-6 and a 4 speed standard that is all i know at this time :help: Great site by the way :thumbsup:
mvusse Posted February 26, 2009 Posted February 26, 2009 Everything on the front of Comanches interchanges with Cherokees. So any Cherokee front axle (but you do need to check the gear ratio). I believe the only front axle used was a Dana 30. Other vehicles may possibly interchange, like YJ or Grand Cherokee?
Rockyrider367 Posted February 26, 2009 Posted February 26, 2009 A YJ axle should work but you will need to make your axle brakets to have it bolt up as the MJ is a coil sprung front end and the YJ is leaf spring. But other than that it should work. I don't know about a ZJ but they were still dana 30s and coil sprung but I don't know if it will bolt up you may need to change the suspention mounts.
Pete M Posted February 26, 2009 Posted February 26, 2009 XJ/MJ are a direct swap. TJ/ZJ are a direct swap, but are low pinion (as are 00+ XJs). YJ would need extensive welding. Also, I think the 2.8L v6 only had 5 speeds with it from the factory. But the 4-speed version of the trans is a direct swap, so it's possible that it was replaced at some point in time.
Comanche County Posted February 26, 2009 Posted February 26, 2009 Yep, gotta 84' Dana 30 from a XJ Reekee under mine.
95whitetrash Posted February 27, 2009 Author Posted February 27, 2009 XJ/MJ are a direct swap. TJ/ZJ are a direct swap, but are low pinion (as are 00+ XJs). YJ would need extensive welding. Also, I think the 2.8L v6 only had 5 speeds with it from the factory. Cool. Thanks guy's, I knew i could count on you for a fast and accurate response still just dong research on this MJ BEFORE i buy it, but it looks like i will have it really soon! :wavey: :wavey:
