comancheman Posted February 24, 2009 Share Posted February 24, 2009 so inspection time is coming up and i needed to do the front brakes and figured while doing that might as well get rid of the rear propvalve and install the new booster/mastercyl ive had sitting in a box in my closet for over a year. i ended up doing front pads, calipers, and rotors new lines every where except passenger front and put in the new booster/master combo. i can not get fluid to the rear end. ive gravity bled for probably 8 hours and also bled the normal way for much longer than ive ever had to in the past. i realize that theres alot of air in the new line that runs front to back but its getting ridiculous. i never had any real braking power in the rear and always attributed this to the rear prop valve. now I'm puzzled as to whats actually going on. also maybe two years ago i replaced rear wheel cyls drums shoes and hardware. i was able to bleed the wheel cylinders and had good fluid coming out then but still never had them actually function. any tips, tricks, or suggestions? TIA, Tim Link to comment Share on other sites More sharing options...
Eagle Posted February 24, 2009 Share Posted February 24, 2009 So you now have a single brake line from the rear flex hose direct to the front metering block below the master cylinder? Are you using the MJ metering block, or an XJ or ZJ proportioning valve? If you're using the MJ metering block, which port did you run the rear line from? "Nose," or bottom? Link to comment Share on other sites More sharing options...
comancheman Posted February 24, 2009 Author Share Posted February 24, 2009 I'm using the mj metering block and plugged the nose port and ran a new line from the front bottom port. Link to comment Share on other sites More sharing options...
comancheman Posted February 24, 2009 Author Share Posted February 24, 2009 IDIOT!!!! thanks for stimulating the brain eagle. i suddenly feel so stupid. o well what can i say it was 11:30pm and about 10 degrees when i did it. Link to comment Share on other sites More sharing options...
maddzz1 Posted February 24, 2009 Share Posted February 24, 2009 comancheman said: IDIOT!!!! thanks for stimulating the brain eagle. i suddenly feel so stupid. o well what can i say it was 11:30pm and about 10 degrees when i did it. Well, what did you do? Link to comment Share on other sites More sharing options...
Eagle Posted February 25, 2009 Share Posted February 25, 2009 The nose outlet is the one that runs the rear brakes. The one he used is actuated only if the front brakes fail. He needs to reroute the hard line to the "nose" of the metering block. Just like in Pete's photo. (Great minds think .... and work ... alike.) Link to comment Share on other sites More sharing options...
Pete M Posted February 25, 2009 Share Posted February 25, 2009 Been there, done that. You aren't the first and likely won't be the last to make that little blunder. :D Link to comment Share on other sites More sharing options...
Eagle Posted February 25, 2009 Share Posted February 25, 2009 ^^^ Yeah -- THAT photo. Eagle said: Just like in Pete's photo. (Great minds think .... and work ... alike.) Notice how the line from the "nose" on Pete's loops up and back and goes directly to a coupling -- and the line beyond the coupling looks suspiciously like it might once have gone to that bottom outlet that's now plugged. Don't be too hard on yourself. It's easy to get confused, because on the XJ front proportioning valve there is no "nose" outlet, and that line would go to where you ran it. Making it up like Pete's fix would make it easy to convert to an XJ proportioning valve down the road. Link to comment Share on other sites More sharing options...
Pete M Posted February 25, 2009 Share Posted February 25, 2009 Eagle said: Making it up like Pete's fix would make it easy to convert to an XJ proportioning valve down the road. Then I must have done it all on purpose. :D Link to comment Share on other sites More sharing options...
comancheman Posted February 25, 2009 Author Share Posted February 25, 2009 Thanks guys, now I'm excited to get back from school and get it back on the road. ive missed drivin it the past few weeks. Link to comment Share on other sites More sharing options...
