Oizarod115 Posted July 20, 2006 Share Posted July 20, 2006 changin the waterpump on my 89, got the pump out, and i can't get this MEFFING TUBE OFF, there is no nut to grab it by, and my vise grips as tight as i can get them do nothing but dig into and move the metal on the tube. HOW IN THE WORLD DO I GET IT OUT? and, how can you tell if the old one is bad or not? it seems fine to me, but its gotta be bad... how do you tell once its out? PLEASE HELP ASAP. gracias, nick Link to comment Share on other sites More sharing options...
Stumpy Posted July 20, 2006 Share Posted July 20, 2006 u talking about the small pipe that is coming out by the upper hose inlet? i used a monkey wrench when i changed mine. Link to comment Share on other sites More sharing options...
Pete M Posted July 20, 2006 Share Posted July 20, 2006 Vise grips are over-rated for getting at stuck bolts/nuts. I use my pipe wrench a lot. :wrench: Yeah, I know he's not holding a pipe wrench, but I wanted to use the smilie somewhere. Link to comment Share on other sites More sharing options...
Oizarod115 Posted July 20, 2006 Author Share Posted July 20, 2006 alright, ill try that, what about telling if the pump is good or not. Link to comment Share on other sites More sharing options...
87manche Posted July 20, 2006 Share Posted July 20, 2006 bearings would be rough or the vanes would be gone. Second the pipe wrench, or you can source brass replacements at the hardware store Link to comment Share on other sites More sharing options...
Oizarod115 Posted July 20, 2006 Author Share Posted July 20, 2006 pipe wrench worked wonders thanks, i guess this pump is good? but it was weepin sooo idk? Link to comment Share on other sites More sharing options...
fiatslug87 Posted July 20, 2006 Share Posted July 20, 2006 If it was weeping you need a new pump. That's the point of weep holes. Link to comment Share on other sites More sharing options...
