glundblad Posted January 31, 2009 Posted January 31, 2009 Has anyone heard anything positive about putting a performance chip on a Comanche 4.0 or an XJ 4.0? Good or bad?? I always assumed they were a hoax but I had a guy try to tell me they really work. :banana:
BLHTAZ Posted January 31, 2009 Posted January 31, 2009 Depends on what year engine you have. If it is a Renix era ('87 - '90), then you are out of luck as far as I know. If it is the HO ('91 & newer), you can get things for them that do make some difference, but they are typically kind of expensive and usually not worth the money.
702_MJ Posted January 31, 2009 Posted January 31, 2009 i have a JET stage 2. They say it adds 25% HP and like 10 ftlb of torque. Not completely true. I'm thinking more along the lines of 10-15hp and 5-10 ftlb of torque if your lucky. But hey you would have to see dyno numbers. I got a 4.0 HO 135000 k&n intake, aftermarket header, and header back exhaust. Seat of pants theres a little bit more there but i don't know if its worth it to you. like $260 from summit racing. Hope that helps.
HOrnbrod Posted January 31, 2009 Posted January 31, 2009 Depends on what year engine you have. If it is a Renix era ('87 - '90), then you are out of luck as far as I know. If it is the HO ('91 & newer), you can get things for them that do make some difference, but they are typically kind of expensive and usually not worth the money. Taz is right on the first part; if you have a Renix I'm pretty sure you are SOL. But he's semi-wrong on the second part, they ARE worth the money to get the most out of a stroker engine (at least the Unichip is) and it's proven on the Hesco dyno. I posted these results over on the strokers forum: http://www.jeepstrokers.com/forum/viewtopic.php?f=5&t=387. Don't remember if I posted this here or not. I also don't think a chip will do much for a non-stroked HO engine with a couple of add-ons, not economically wise. :D So Taz was right about that part too. Taz was mostly right again. He also loves the Stillers. Damn you Taz! :cheers:
BLHTAZ Posted January 31, 2009 Posted January 31, 2009 Damn Don...I am confused now... :rotf: I think I'll just go check out the Steeler website for a while again... :clapping:
702_MJ Posted January 31, 2009 Posted January 31, 2009 Taz is right on the first part; if you have a Renix I'm pretty sure you are SOL. But he's semi-wrong on the second part, they ARE worth the money to get the most out of a stroker engine (at least the Unichip is) and it's proven on the Hesco dyno. I posted these results over on the strokers forum: http://www.jeepstrokers.com/forum/viewtopic.php?f=5&t=387. Don't remember if I posted this here or not. I also don't think a chip will do much for a non-stroked HO engine with a couple of add-ons, not economically wise. :D So Taz was right about that part too. Taz was mostly right again. He also loves the Stillers. Damn you Taz! :cheers: so that uni chip works pretty good huh, hmm. might have to get that after i do that 4.7 stroker kit ive been wanting from hesco. LOL too bad that JET one i got is kinda stuck on there pretty well.
freegdr Posted October 15, 2010 Posted October 15, 2010 i have found these don't no if they work or not you posted this a long time ago www.gforcechips.com
Silver88 Posted October 16, 2010 Posted October 16, 2010 Hey Taz, good to see you drop in. :cheers: Sorry for the interuption.
glundblad Posted October 16, 2010 Author Posted October 16, 2010 Hey Taz, good to see you drop in. :cheers: Sorry for the interuption. No Taz. This is just an old resurected post.
Silver88 Posted October 16, 2010 Posted October 16, 2010 Doh! Boy do I feel stupid. :dunce: Guess I should pay more attention to dates, huh? :oops:
