MJ.rusty Posted December 31, 2008 Share Posted December 31, 2008 anyone know what the thread patter is on the valve cover bolts or where i can get new ones. and also i broke the front bolt off in the block. anyone know how to go about getting the remaning bolt out. don't want to drill and tap it myself and start another problem without finding out if that is the easiest way. o and i heard that a valve cover from a 2000 xj would fit my 1990 and is actually a better design. true or false? thanks in advance Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 31, 2008 Share Posted December 31, 2008 Those should be a metric 14mm - 20x1. You could try soaking it with something like PB Blaster for a little while then see if a reverse drill bit will take it out, but the drilling & easy out is probably going to be what you have to do. Yes...the late model valve covers will work and they are an upgrade. If you do a little search, there is a fairly recent article about doing the swap on here. :thumbsup: EDIT: Here it is... viewtopic.php?f=2&t=12871&p=129427&hilit=ho+valve+cover#p129427 Link to comment Share on other sites More sharing options...
bigd44889 Posted January 2, 2009 Share Posted January 2, 2009 :agree: Link to comment Share on other sites More sharing options...
aemsee Posted January 3, 2009 Share Posted January 3, 2009 14mm valve cover bolt? :eek: Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 3, 2009 Share Posted January 3, 2009 anyone know what the thread patter is on the valve cover bolts or where i can get new ones. and also i broke the front bolt off in the block. anyone know how to go about getting the remaning bolt out. don't want to drill and tap it myself and start another problem without finding out if that is the easiest way. Valve cover bolts are not metric; they are 1/4" x 20 UNC. Link to comment Share on other sites More sharing options...
BLHTAZ Posted January 3, 2009 Share Posted January 3, 2009 HMMM...it appears the the sheet I was looking at is missing the ' / ' between the 1 & 4 ... :nuts: so I though it was 14mm. I thought that sounded a little weird, but it was right there in front of me. ;) Link to comment Share on other sites More sharing options...
aemsee Posted January 3, 2009 Share Posted January 3, 2009 Just funnin' with ya Brent :D . Sorry we couldn't get together in Orlando. Just no time. Link to comment Share on other sites More sharing options...
