Starter
I think my starter went bad last night, my batt. tested good, and my alt. tested good, and my truck still won't start. So what is the best way to test the starter?
remove it and take it to a parts store where they can test it (NAPA, Autozone, Advance etc.)
Your truck's automatic, isn't it?
ah. Marcel, I see where you're going with this :popcorn:
Yea.......you guys started it........but didn't finish it :roll:
If your MJ is automatic, take it out of Park, into Neutral and see if it will start (turn the starter over) Run the gear selector up and down a couple of times and back into Park and see if it will turn the starter.
If it dose, your NSS is sticking. Or, you just didn't have the gear selector in the perfect spot, and it's shorting out the starter relay, the safety feature for not starting the truck in gear.
It could be just the gear selector not set just right, or.......your NSS needs cleaning.
See this - http://www.lunghd.com/Downloads_and_Links/NSS.zip
I do not mean to jump on this thread about this but Does a starter out of a 5 speed work for the auto trans or is it different?
I know they are different nose cones on Chev's but do not know aout the jeep.
I would like to take the starter out of the 5 speed truck and put it in the auto so I can move it in the yard if I can that is why I am asking.
THanks for any help.
There is no difference between the auto and manual starter for the 4.0 engine.
The 4.0 and 2.5 starters are different.
There all Mitsubishi based starters.
And.........The cross check- for the 4.0-
AMERICAN MOTORS
1988 EAGLE
JEEP
1987 - 1998 CHEROKEE. 1988 J20
1987 - 1992 COMANCHE. 1987 - 1990 WAGONEER
1993 - 1998 GRAND CHEROKEE. 1988 - 1991 GRAND WAGONEER
1988 - 1995 WRANGLER. 1997 - 1998 WRANGLER. 1988 J10
It's a pretty common, widely used starter.
