comanche coil buckets
For what it's worth (which is very little at this point), that little extra bracket that MJs have is not necessary on a stock MJ. XJs don't have it. Not sure if you can work around that though. The easiest solution might be to have new shorter arms made up. :(
To me the solution would be to remove the added x-member brace.... and put the bracket where it is suppose to be. :nuts: To have a different set of arms made up would add considerable expense to the kit.
  • Replies 51
