Hinge Pin
It's a 6 mm. But I couldn't find any so I used 1/4" bolt from local hardware. You might have to run a 1/4 bit through it to clean the hole up slightly and allow the bolt to slide through. Dip it in oil and tap it lightly. It's an easy enough task.
