Alright, I'm new to the comanche world but not to the jeep world. Ive had several cherokees in the past and loved them. I have the option of buying a 86 comanche long bed for $800. Its a 4cly, 4 speed, 4wd, and the body dosent any rust on it. Should I spend the money on this? I want to build it up in the futer with 6-7in lift, 35's, 4.0 HO and 5 speed swap, and dana 44 f/r. It runs and drives great, but the brakes are a little soft. Like i said, the cherokee in the past I have fixed up so I have the jeep knowlage, but I am not too familiar with the 2.5 4cyl. Or should I save my $$$$ for a "newer" comanche with the 6cyl and 5 speed in it already?
Oh and to add to everthing, I do need a second vehical.
Here is how to put pictures on here... viewtopic.php?f=6&t=11077
It has chnaged a little bit and i need to update this instruction post, but it will get you going.
As for the truck...if it is in good shape as you say, then yes, it's definitely worth the money :thumbsup:
Thanks alot. Buy the way.....Does anybody know if 97+ doors fit on a MJ? I know that they will fit on a 84-96 Cherokee, and I think 84-96 doors will fit on a MJ. Just a thought.
here's the pics
Image Not Found
Comanche doors ARE 4-door Cherokee front doors. The same modifications are needed to use 97+ Cherokee doors on a Comanche as are needed to use them on a '96 or older Cherokee.
If you can find a rust-free MJ and the long wheelbase won't be an issue for your intended use -- don't hesitate. Engines and drive trains can be built and swapped, but they ain't making rust-free (or any other kind of) Comanches any more.
