90eliminator Posted December 8, 2008 Share Posted December 8, 2008 ok is there a way to bypass the CPS totally, feed it with a power source of some sort, fool the computer somehow... I did a search but came up with no topics like this.... Is it doable....????? Link to comment Share on other sites More sharing options...
Pete M Posted December 8, 2008 Share Posted December 8, 2008 No. It is a vital piece of equipment. It tells the computer where the engine is in its rotation. Without it, the computer won't fire the engine. Which is a good thing, 'cause all sorts of very bad things would happen if the computer fired the sparkplugs and injectors at the wrong times. :thumbsup: Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 8, 2008 Share Posted December 8, 2008 No. It is a vital piece of equipment. It tells the computer where the engine is in its rotation. Without it, the computer won't fire the engine. Which is a good thing, 'cause all sorts of very bad things would happen if the computer fired the sparkplugs and injectors at the wrong times. :thumbsup: hence the holes burned through three of the pistons in my 87 MJ right now... :ack: :yes: as Pete said, you need it. wrong ignition timing can cause lean or rich burns, which will utterly destroy an engine if left unchecked. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 8, 2008 Share Posted December 8, 2008 You can always use the Hesco relocation kit to move the CPS up front on the harmonic balancer. Easier to work on....... http://www.hesco.us/shop.asp?action=details&inventoryID=43097&catId= Link to comment Share on other sites More sharing options...
