smartazz19 Posted December 2, 2008 Share Posted December 2, 2008 Hey guys, So my right and left blinker stopped working. I got a new flasher and still have nothing, checked the fuses, they are good. I was gonna try and diagnose it, before i bought a new turn signal arm or switch. I pulled the steering wheel and everyhing "looked" good, but obviously something isnt connecting. Does anybody have a diagram on which wires in the column are for the blinkers? My hazards do work as usual with the pull switch thing on the column.. Thanks! :D Link to comment Share on other sites More sharing options...
Akula69 Posted December 2, 2008 Share Posted December 2, 2008 BLTAZ posted a electrical manual here in the forum...http://comancheclub.com/forums/viewtopic.php?f=9&t=12734 and that will be of great help. The turn signal/wiper wiring is actually the flat, multi-colored harness that goes down the column and is visable coming out of the bottom of the column shroud. It may be encased in a black plastic sheath for protection. You can see it in this picture...with the white plug at the end: Link to comment Share on other sites More sharing options...
jaekl Posted December 2, 2008 Share Posted December 2, 2008 You didn't say what did happen. Do they come on but don't blink or is there no light at all? With no light the problem is probably power to switch to relay. If the lights go one but do not blink the problem is probably down stream and probably ground at the lights. That's my problem there is a voltage drop such that the battery voltage is no enough to make the left side blink (it just glows). The alternator must be putting out enough to make it blink and it's getting slow. I suspect the front socket ground, but hey the roof doesn't leak when it's not raining, I'll get to it. Link to comment Share on other sites More sharing options...
smartazz19 Posted December 2, 2008 Author Share Posted December 2, 2008 Thanks for the link, that is exactly what i needed. They do not come on at all when i hit the switch to go left or right. But the hazards work properly and everything lights up.. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 2, 2008 Share Posted December 2, 2008 Power for your turn signal switch comes into the column on pin L at the connector at the base of the column. Disconnect this connector and see if you have 12V on pin L. If you do, most likely the turn signal switch is bad or the wire from the connector to the column switch is open inside the column. Pin K is the 12V supply for the emergency flashers, and is independent from the normal turn signals. Link to comment Share on other sites More sharing options...
smartazz19 Posted December 3, 2008 Author Share Posted December 3, 2008 Power for your turn signal switch comes into the column on pin L at the connector at the base of the column. Disconnect this connector and see if you have 12V on pin L. If you do, most likely the turn signal switch is bad or the wire from the connector to the column switch is open inside the column. Pin K is the 12V supply for the emergency flashers, and is independent from the normal turn signals. U rock. :cheers: I appreciate the help.. Ill be messing with it this weekend, so well see what i find. Link to comment Share on other sites More sharing options...
carnuck Posted December 5, 2008 Share Posted December 5, 2008 One more thing: There are TWO flashers! Have a nice day! :wavey: Link to comment Share on other sites More sharing options...
smartazz19 Posted December 5, 2008 Author Share Posted December 5, 2008 One more thing: There are TWO flashers! Have a nice day! :wavey: Ya last weekend I swapped them to see if they were both functioning and they indeed both worked. I'm gonna investigate the switch on Saturday. :D Link to comment Share on other sites More sharing options...
