Akula69 Posted November 29, 2008 Share Posted November 29, 2008 I recently purchased another dash clock for the Christmas MJ, as the two I had already refused to work properly. The clock would work, but the display was quite dim. Unfortunately, the new one works no better, and it's really bugging me :fs1: I used to have a link to a page that showed the various types of clocks, and more importantly, the wiring for each. I believe the dash wiring has a glitch and need to see the corresponding clock diagram. (I have the electrical manual for the dash harness). Does anyone remember that page (or link)? Thanks in advance :D Link to comment Share on other sites More sharing options...
Boilermaker Posted November 29, 2008 Share Posted November 29, 2008 Are you looking for this one from Go-jeep's website: http://gojeep.willyshotrod.com/HowtoDashClock.htm Link to comment Share on other sites More sharing options...
Akula69 Posted November 29, 2008 Author Share Posted November 29, 2008 Are you looking for this one from Go-jeep's website:http://gojeep.willyshotrod.com/HowtoDashClock.htm Yup. Thanks! Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 29, 2008 Share Posted November 29, 2008 The clock from a 91 model has by far the brightest display. You could hardwire one in using the above link. Link to comment Share on other sites More sharing options...
Mnut Posted December 14, 2008 Share Posted December 14, 2008 There is also a resistor inside the clock that can be fried causing a dim display. I have sucessfully replaced it with a like valued resistor from Radio Shack. ;) Link to comment Share on other sites More sharing options...
jtdesigns Posted December 14, 2008 Share Posted December 14, 2008 There is also a resistor inside the clock that can be fried causing a dim display. I have sucessfully replaced it with a like valued resistor from Radio Shack. ;) Wow a first post being really informative... I don't know what year clock it came out of, but I have one that says quartz in white letters and it is really brite and easily readable.. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 14, 2008 Share Posted December 14, 2008 There is also a resistor inside the clock that can be fried causing a dim display. I have sucessfully replaced it with a like valued resistor from Radio Shack. ;) Would be nice if you could detail how you found the fried resistor (obvious or by troubleshooting) and what year clock you are referring to. Link to comment Share on other sites More sharing options...
