Rayko~Tux83 Posted November 26, 2008 Share Posted November 26, 2008 Hi very one, i'm new here! I have a Comanche '88 Sport Truck. Well I live in mexico and here is my problem: a few days ago my truck broke down, I was driving it and turn off. So I pull over and try to started again, it run a few sec's and when off again... so felt it there. later on i check it and i saw the ground strap (from dash panel to the engine) I think is called, cut and burn. I put a thick wire to replace it, but I notice that the gauges from the instrumental panel doesnt work. everything seems alright... got the truck running again...can any one tellme what can it be or have an electric schematic.... Thanks every one... P.D. I almost forgot... no fuse was burn... all are working...! Link to comment Share on other sites More sharing options...
Eagle Posted November 26, 2008 Share Posted November 26, 2008 There is a fuse for the gauges. It is located in the fuse panel, which is beside/above the driver's left foot. The fuse you are looking for is located toward the bottom right corner of the fuse panel, next to the top of the hazard warning flasher can. It takes a 7-1/2-amp fuse. Check that first. Link to comment Share on other sites More sharing options...
Rayko~Tux83 Posted November 26, 2008 Author Share Posted November 26, 2008 Yeah, check that one already, and its fine!... can it be a relay?? or where else can I check??? Link to comment Share on other sites More sharing options...
fiatslug87 Posted November 26, 2008 Share Posted November 26, 2008 Here's the wiring manual for the '88 http://comancheclub.com/forums/viewtopi ... =9&t=12734 Link to comment Share on other sites More sharing options...
Rayko~Tux83 Posted November 26, 2008 Author Share Posted November 26, 2008 thanks fiatslug87 i'll check it out!! thank you very much... Link to comment Share on other sites More sharing options...
BLHTAZ Posted November 26, 2008 Share Posted November 26, 2008 It seems that they have you on the right track so I just say... Welcome to the Club :cheers: Link to comment Share on other sites More sharing options...
