What is the easist way to pull the driver's side front bunper bracket straight that doesn't cost me $150. My brakes went out and I rear ended a Tundra and now I am tryin to get my front end fixed so I can get an OEM bumper
Your close-up photo is so close-up I can't see what the problem is.
You asked about bumper brackets. Are you now saying that the frame "ear" is bent? That's an integral part of the chassis. A good body shop could cut one off a wreck and weld it into yours -- for about five times what the truck is worth. Moe than likely, what you need is a come-along, a couple of bottle jacks, a torch to heat up the metal, and a BFH.
