r.j.c.omanche Posted November 16, 2008 Posted November 16, 2008 :help: i have a '86 2.5L with a headgasket (? i think?) problem. i have a chance to get a '88 XJ 4.0, auto for cheap, cause it's rusty. is this a good year? bad year? does it matter? i know it would not be a H.O. motor, so my next question: what's the differences between a 4.0 and a 4.0 H.O. ?? :dunno: thanx
mvusse Posted November 16, 2008 Posted November 16, 2008 A 4.0 HO has an ignition system based on a Chrysler ECM, the older 4.0 has an ignition system based on a Renix ECM. There are other changes on the HO also, to provide better airflow through the heads, a little different cam and some other stuff. The 1987 4.0 makes 173 hp. 88 through 90 makes 177 through larger fuel injectors, and the HO ones make 190 with the torque peak a bit higher I believe. Mechanically, they are basically still the same engine, and you could start an endless debate about which one is actually better. A bigger problem is that the 86 fire wall was never designed for a 4.0, meaning you may have to make a 1/2" or 3/4" modification with a hammer to make the engine clear it. Still not a terribly big problem...
Eagle Posted November 16, 2008 Posted November 16, 2008 The 1987 4.0 makes 173 hp. 88 through 90 makes 177 through larger fuel injectors, and the HO ones make 190 with the torque peak a bit higher I believe. Yeah ... like about 2,000 RPM higher. IIRC the Renix torque peak was 2,250 RPM. The HO torque eak was 4,000 RPM. Further proving that Chrysler Corporation had zero understanding of what a Jeep really is when they bought Jeep from AMC.
r.j.c.omanche Posted November 17, 2008 Author Posted November 17, 2008 okay, here's a can of worms for everyone.... anybody ever done or seen a diesel swapped into a MJ? i absolutly love diesels, it is a horrible, sick fetish of mine that I'm not afraid to admit. i know there are kits available ( somewhere) to swap a VW disel into a 'yoda, so worst case (as far as parts availbility) get a 'yoda bell housing to bolt onto the AX tranny. :yes: :brows: :thumbsup: or is just another crazy thought of mine that is proving that i shouldn't have quit drinking. :popcorn:
HKB3 Posted November 17, 2008 Posted November 17, 2008 Diesel could be good, I have seen a Isuzu diesel in a samari Maybe a cummins 4BT in a MJ
r.j.c.omanche Posted November 17, 2008 Author Posted November 17, 2008 those 4bt cummins are sweet, but they are tall. i know to get one under the hood of my wagoneer i would have needed at least 3" body lift and 4"-5" suspenstion lift :( . that why i didn't do it
jtdesigns Posted November 17, 2008 Posted November 17, 2008 This guys lurks around here from time to time I believe.
r.j.c.omanche Posted November 17, 2008 Author Posted November 17, 2008 :bowdown: :clapping: :drool: :bowdown: :clapping: :drool: i don't know what else to say. that is the coolest thing i've seen in a long time.
