smithe1811 Posted November 8, 2008 Share Posted November 8, 2008 I want to make a ram air system for my 88 and was wondering if anyone had some insight on how do make it. i also want to find an aftermarket intake to replace my stock one first, some help there would be great too. Thanks Erik :beerhead: Link to comment Share on other sites More sharing options...
Pete M Posted November 8, 2008 Share Posted November 8, 2008 Well, the only insight I've got is, on the freeway, the hole in the hood of my 5" lifted 88 pulls air out of the engine compartment (which then finds its way in to the cab :ack: ). Link to comment Share on other sites More sharing options...
Akula69 Posted November 8, 2008 Share Posted November 8, 2008 On the old Pontiac Trans Am there was a hood scoop that collected ram air and diverted it through a special flange that sat on top of the air cleaner. It had a foam rubber lip on the top that tightly sealed it to the bottom of the scoop. In our trucks I don't believe you'd have enough space between the top of the valve cover and the bottom of the hood for a similar set up, but that would be one way to get it done. Link to comment Share on other sites More sharing options...
deziped Posted November 8, 2008 Share Posted November 8, 2008 Under 103 un 1/4 MPH it probally won't be benefical in HP gain. :dunno: Link to comment Share on other sites More sharing options...
smithe1811 Posted November 9, 2008 Author Share Posted November 9, 2008 On the old Pontiac Trans Am there was a hood scoop that collected ram air and diverted it through a special flange that sat on top of the air cleaner. It had a foam rubber lip on the top that tightly sealed it to the bottom of the scoop. In our trucks I don't believe you'd have enough space between the top of the valve cover and the bottom of the hood for a similar set up, but that would be one way to get it done. Thats pretty much how i was going to set it up, i have a few ideas in mind that i think will work, but before i made anything i wanted to find a new intake, like the k&n FIPK, i don't think they make one for the renix but i was hoping someone would know who did. Erik :beerhead: Link to comment Share on other sites More sharing options...
wolfpackjeeper Posted November 9, 2008 Share Posted November 9, 2008 ram air is inneffective at speeds of less than about 250mph. It works on the principle of your car compressing the air in front of it, forcing it into the intake. at slow speeds, the excess air will "spill" around the edges of your intake. "ram air" on pontiacs is a marketing term. Air will not compress on itself until it cannot hear it coming, meaning approaching the speed of sound. THe scoops do make for pretty good cold air entrance points though Link to comment Share on other sites More sharing options...
jtdesigns Posted November 9, 2008 Share Posted November 9, 2008 On the old Pontiac Trans Am there was a hood scoop that collected ram air and diverted it through a special flange that sat on top of the air cleaner. It had a foam rubber lip on the top that tightly sealed it to the bottom of the scoop. In our trucks I don't believe you'd have enough space between the top of the valve cover and the bottom of the hood for a similar set up, but that would be one way to get it done. That my blue lighted buddy is called a shaker hood..... yummmm I want to do one of those on my truck.. Link to comment Share on other sites More sharing options...
