james750 Posted October 20, 2008 Share Posted October 20, 2008 Has anybody tried to use TJ seats in an MJ? I think that they wouldnt be too much harder to fab up brackets for than 2dr XJ seats, but are much more available. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted October 20, 2008 Share Posted October 20, 2008 eh. I disagree with the availability part...I've not once seen a TJ in the junkyard that was intact by any means, and I've only seen one at that. the seats would probably be too high for my taste (in the headrest area) and require more mounting work to be done, not less (they don't mount on the same tracks even) Link to comment Share on other sites More sharing options...
Darren Posted October 20, 2008 Share Posted October 20, 2008 I've seen TJ buckets in an MJ and they looked great. The guy I was talking to said they were real easy to mount to the MJ bench brackets. Link to comment Share on other sites More sharing options...
LoTGoD Posted October 20, 2008 Share Posted October 20, 2008 eh. I disagree with the availability part...I've not once seen a TJ in the junkyard that was intact by any means, and I've only seen one at that. What about on the boards? I've seen a lot of guys getting rid of them cheap because they upgraded to MasterCraft or Corbeau seats. FYI - Corbeau states they have replacement brackets that will bolt DIRECTLY in to an MJ to run their seats... I don't doubt it, but I'd have to see them first. goblazers_6 - I'd like to see some pics of that guys setup if that is possible. I have access to a bunch of TJ seats, and if it is easier than the 98 XJ seats I have, I will go that route.... Link to comment Share on other sites More sharing options...
