led_balloon Posted October 16, 2008 Share Posted October 16, 2008 I'm planning and changing all the fluids in the front and rear diff. I will be replacing the gear lube with lucas syn 75w90. I just need to no if i need friction modifier, as i do not no if its a lsd diff. its a 92 eliminator dana 30 and 35. thanks for the help also i found and a better flowing manifold from a newer jeep(xj) for a $100, it has more than 100k miles on it. is this a good price. Link to comment Share on other sites More sharing options...
BLHTAZ Posted October 16, 2008 Share Posted October 16, 2008 I don't know if the manifold is a good deal or not, but you will have to find out if you have LSD. If you PM me the last 9 digits of you VIN I can tell you :cheers: Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 16, 2008 Share Posted October 16, 2008 also i found and a better flowing manifold from a newer jeep(xj) for a $100, it has more than 100k miles on it. is this a good price. Are you talking about the 1999+ intake manifold? Or an exhaust manifold? Link to comment Share on other sites More sharing options...
FxRacing282 Posted October 16, 2008 Share Posted October 16, 2008 I don't know if the manifold is a good deal or not, but you will have to find out if you have LSD. If you PM me the last 9 digits of you VIN I can tell you :cheers: i alawys look for the lsd unit when i pull a cover off. buy the stuff when you get the oil and if you don't need it bring it with you next time you get parts. Link to comment Share on other sites More sharing options...
Oizarod115 Posted October 17, 2008 Share Posted October 17, 2008 if the intake comes with a power steering pump and brackets then yes... if not then no. Link to comment Share on other sites More sharing options...
