Project new life
Slowly but surely it's getting there. Big thanks to High2by and PacificEd for the dash harness. I got it swapped in and everything is working the way it should now. While the dash was out I dyed it to match the suade/ leather seats and door panels I made for it so now everything matches( aside from some small things). Also needed to get some new trim pieces for the front and at the JY they had 5 or 6 97+ XJ's so I figured I'd make use of the 97+ header panel I had laying around. I scored the grill, bezels and all lenses for a grand total of $25. Got it all together for now and here's a few pics.
  • Replies 57
Might as well add that all the parts are here, just need to find the time to get it together. Axles are '03 f-350 tons, D60 front and 10.5" sterling rear. 35 splines f/r rear disk brakes, Miller locked f/r, 5.38's capped off with Solid covers. Also planning to pick up PSC pump, lines and res this weekend. Not sure wether this will get full hydro or just assist. I still want to keep it streetable.
  • 1 month later...
Got side tracked but here is the status, Boggers got sold and oredered a new set of 39.5x16.5x17 Pitbull Rockers. BallisticFabrication weld on beadlock rings are on the way. Front bracketry almost finished and close to being welded on, new brake rotors, pads and 4 studs to replace the missing ones. Rear perches, 3.5" u-bolts and .5" spring top plates are here and ready to go on. Tires are getting mounted on new rims tomorrow, also got a PSC pump kit here already with pump, reservoir, hoses and a derale cooler. Tomorrow ordering a PSC 1.75"x 8" assist cylinder with hose kit and the complete box rebuild kit will be at advance auto tomorrow. I also scored some MJ buckets with MJ center console so I'll have the seats recovered and ready to bolt into the new floor in the next few weeks. Interior will be pretty "pimpin" when it's all done but more about that as it comes together.
New t-case is in, driveshafts are hooked up front and rear, steering linkages are done and installed, coils are in the final position, front shock mounts are done, beadlock rings are in hand, beadlock hardware and cage tubing will be here friday. It moved...
